I followed up here but no response:
Hi @bjoish
Thanks for bringing the doc issue to our attention.
Could you please try the below latest API helm chart and let us know in case issue persist:
helm fetch https://helm.ngc.nvidia.com/nvidia/jarvis/charts/jarvis-api-1.1.0-beta.tgz --username='$oauthtoken' --password=<YOUR API KEY>
and then I tried installing the helm chart:
$ helm install --namespace jarvis jarvis .
Error: template: jarvis-api/templates/modeldeploykey.yaml:1:12: executing “jarvis-api/templates/modeldeploykey.yaml” at <len .Values.modelRepoGenerator.modelDeployKey>: error calling len: len of nil pointer
and I am getting the same error as above
$ helm fetch https://helm.ngc.nvidia.com/ea-2-jarvis/charts/jarvis-api-0.2.1-ea.tgz --username=’$oauthtoken’ --password=$NGC_API_KEY
Error: failed to fetch https://helm.ngc.nvidia.com/ea-2-jarvis/charts/jarvis-api-0.2.1-ea.tgz : 401 Unauthorized
I am using EKS and need streamline EKS instructions
NVES
June 24, 2021, 9:37pm
2
Please check the below link, as they might answer your concerns
This is the API Reference documentation for the NVIDIA TensorRT library. The following set of APIs allows developers to import pre-trained models, calibrate networks for INT8, and build and deploy optimized networks with TensorRT. Networks can be...
That doesn’t solve any issues I am currently facing - my issues are in regards to helm charts used for jarvis and documentation around it (see above)
instructions are here:
https://docs.nvidia.com/deeplearning/jarvis/user-guide/docs/samples/jarvisasreks.html
Hello any updates on this? Need help on this ASAP
Hi @yuvraj1 ,
We recommend you to post your concern on Jarvis forum to get better help. Please add Jarvis tag while posting in below link
Looking for help or guidance for any NVIDIA software products supporting AI & Data Science? This is the place.
Questions about specific hardware configurations live elsewhere.
Thank you.
