I have deployed AI Agent for Telecom Network Configuration Planning on two A10 GPU’s instance with 480 GB memory running Oracle Linux 9.6. I can see the interface on the browser. But when i press start network button it tries to start the network but fails. Please help in resolving this issue so i can execute this blueprint. Appreciate a prompt response.
Hi Seemant,
We recommend testing this on an Ubuntu machine with at least 16 cores. The 5G Lab installation has specific instructions that are set up for Ubuntu, so we are not sure this will work on Oracle Linux 9.6. Please see the reference to the OAI interface page. OpenAirInterface – 5G software alliance for democratising wireless innovation
Thanks amparo. I have now deployed the blueprint on 30 core A10 GPU’s using ubuntu 22.04. But i am now not able to access the application on the browser. it gives a “This site can’t be reached
129.80.10.34 refused to connect”.
I am using the public ip of my instance with port 8501. I have enabled access to port 8501 on my cloud security list and my ubuntu firewall is inactive. Appreciate any prompt help in this regard.
Semant, it looks like an access issue. Can you verify if you can ping the IP address from your machine? Alternatively. Could you try to test in our brev.dev environment? Console | Brev.dev let me know if you need additional credits? Thanks!
Hi Amparo, I was able to access the application on the browser. And when i click on start network ,it starts successfully. But when i click on monitoring or ask a query to the configuration agent. i am getting the attached error. appreciate any help in this regard.
thanks
Seemant
Hi Amparo,
Please let me know you inputs. Appreciate the prompt help.
Seemant
can somebody help me with this issue. I am trying to deploy this blueprint on Oracle cloud , so as to be able to use this for my telecom customers. Appreciate any prompt response.
Seemant
