Deployment of custom pipeline on jetson AGX Xavier with Deep stream
Hi Team,
  • We are testing Person Zone tracking pipeline with Deep stream on jetson AGX Xavier with jetpack 5.1, CUDA 11.4 which is mounted on Aver media carrier board AG411.
  • Installed deep stream 6.2.0 on jetson AGX Xavier with 28GB memory size and 62GB RAM.
  • Verified the Deep Stream installation by running the default sample applications 1 and 2, but it’s not work, and I received the following error:
    One element could not be created. Exiting.
  • We tried to remove the blacked list using the command: rm -rf ~/.cache/gstreamer-1.0/
    But its not removed, i have installed the correct deep stream version for the jetpack 5.1 based on the below link: JetPack SDK | NVIDIA Developer, Installation — DeepStream documentation
Can you please help us to resolve this issue
Regards
Karthiga N
Please add some log in the samples you have already run to find out which element caused problem.
You can modify the source code like below.
source code
  if (!source || !h264parser || !decoder || !pgie
      || !nvvidconv || !nvosd || !sink) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
Modified code:
if (!source) {
    g_printerr ("Source could not be created. Exiting.\n");
    return -1;
 if (!h264parser) {
    g_printerr ("H264parser could not be created. Exiting.\n");
    return -1;
Hi @yuweiw , thanks for the reply
I tried the above solution which you suggested and came to know it was falling at this point of the below source code:
streammux = gst_element_factory_make (“nvstreammux”, “stream-muxer”);
if (!pipeline || !streammux) {
g_printerr (“One element could not be created . Exiting.\n”);
return -1;
Its giving the same error : One element could not be created .
I checked for the blacklisted plugins, it showing below 14 blacklisted files:
Blacklisted files:
libcustom2d_preprocess.so
libnvdsgst_tracker.so
libnvdsgst_ofvisual.so
libnvdsgst_inferserver.so
libnvdsgst_dsexample.so
libnvdsgst_multistream.so
libnvdsgst_udp.so
libnvdsgst_dewarper.so
libgstnvvideoconvert.so
libnvdsgst_preprocess.so
libnvdsgst_infer.so
libnvdsgst_multistreamtiler.so
libnvdsgst_deepstream_bins.so
libnvdsgst_segvisual.so
Total count: 14 blacklisted files
Tried this command : sudo rm -rf ~/.cache/gstreamer-1.0/ to delete the blacklisted files, but its not deleting.
I have tried to reinstall the deep stream but still facing same issue.
Could you please help me to resolve this issue.
Regards,
Karthiga N
Could you check if there is /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so in your env? If there is, you can run the command below to check if there are any missing libraries.
ldd /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so
I tried the above solution which you suggested, two libraries are missing
  • libnvdsbufferpool.so.1.0.0
  • libnvbufsurftransform.so.1.0.0
Attaching Screenshot for reference
Regards,
Karthiga N
