Deployment of finetuned Canary-1B model
I finetuned a Canary-1B on my specific needs. I know there are container to deploy fundamental Canary Model but I need my specific one. Is there any chances to deploy it with Riva. I could convert it to .riva format.
Is there a planned release date for this?
[NeMo W 2025-12-12 09:22:38 nemo_logging:405] Validation schema not found for nemo.collections.asr.models.EncDecMultiTaskModel.
That means Riva does not yet support a pipeline for this network and likely will not work with it.
[NeMo I 2025-12-12 09:22:38 nemo_logging:393] Found model at ./model_weights.ckpt
[NeMo I 2025-12-12 09:22:38 nemo_logging:393] Retrieved artifacts: dict_keys([‘0c8398a508f847cd8bd59e4b391fb2da_tokenizer.vocab’, ‘26b99b2cff9a489b95e055e7141d05f5_tokenizer.vocab’, ‘3a3348731fa8421785ab07078c8e6567_vocab.txt’, ‘5182ad3f6ba2488080f3805810baf58f_tokenizer.model’, ‘5654b2f39e1b4b64987644ebd0233d1b_vocab.txt’, ‘5af22385209c4eb894c46642ccee2f89_tokenizer.vocab’, ‘5fa34f29c97742f8b910d79f5b0a9411_tokenizer.model’, ‘6e1b008246314e9bb08fbec31e7c7579_vocab.txt’, ‘7a529372403346319f8ae58f8dc0d35d_vocab.txt’, ‘7b62cb533aef485aa0802b50ef83a31e_tokenizer.vocab’, ‘87cc2890f22744668b928538994557bb_tokenizer.model’, ‘968096f5c2734235a39c82b46d7c5bb7_tokenizer.model’, ‘cb2826090d7d41ca80bc5eaab6f34fb2_tokenizer.vocab’, ‘eaa88303b71743d4a007daa2d8ed1e7f_tokenizer.model’, ‘f16f5f100961470fa079784134d7e760_vocab.txt’, ‘model_config.yaml’])
Thanks for your help
Hello this.stein
Would you kindly share the code you used to fine tune canary-1b?
I used this one with the configuration of the unified tokenzier.
