11127
April 2, 2018, 4:42pm
1
in the Driveinstall_4.1.8.0 Beta3.0
I just add the rtl8192cu(usb_wifi_driver)(of cause I also its depend mod mac80211)
and then when I compile it, there will be three .ko files depmod clycle.
does anyone could help me to solve the problem?
thanks.
Dear ???,
Could you file a bug for your topic? We will look into it.
Please login to https://developer.nvidia.com/drive with your credentials. Please check MyAccount->MyBugs->Submit a new bug to file bug.
Please share ID here to follow up. Thanks.
11127
April 3, 2018, 3:51pm
3
just now I have solved the problem.
the root cause is that I use the make xconfig in a wrong way.
I hope nvidia add a command :
make -C kernel O=${PWD}/out-t186ref-linux xconfig
after
make -C kernel O=${PWD}/out-t186ref-linux tegra_t186ref_gnu_linux_deconfig
in the “Compiling the kernel” document.
because I couldn’t find where the .config file be saved after configurating the kernel options.
Dear ???,
Thank you for your update and information.
