Depth of Field does not work with Fisheye Lenses?
I am testing out changing the projection type of my Camera in the Fisheye Lens section of the Properties and it seems that when you switch from Pinhole to any other type like fisheyeEquidistant that the camera no longer does Depth of Field. Here are tests shots with an F stop of 0.2. Is this a bug? Testing this out in Create 3.1
Thank you for letting us know about this bug. We will log it and fix it as soon as possible.
Thanks Richard! Do you know, or can you ask internally if there is anyway we can precisely control the barrel distortion of a lens? From making lines perfectly straight, to curve inward, and curve outward?
It seems I am having the same issue. Is this still in backlog?
