Depthwise_conv2d in TensorRT
In conversion to TensorRT from Tensorflow, there is issue at Depthwise_con2d.
The implementation is as in the picture.
https://www.dropbox.com/s/u6cc1a20p881w82/Depthwise2D.png?dl=0
Tensorflow code is as follow.
def gauss_kernel(self, kernlen=21, nsig=3, channels=1):
        interval = (2*nsig+1.)/(kernlen)
        x = np.linspace(-nsig-interval/2., nsig+interval/2., kernlen+1)
        kern1d = np.diff(st.norm.cdf(x))
        kernel_raw = np.sqrt(np.outer(kern1d, kern1d))
        kernel = kernel_raw/kernel_raw.sum()
        out_filter = np.array(kernel, dtype = np.float32)
        out_filter = out_filter.reshape((kernlen, kernlen, 1, 1))
        out_filter = np.repeat(out_filter, channels, axis = 2)
        return out_filter
    def make_gauss_var(self, name, size, sigma, c_i):
        # with tf.device("/cpu:0"):
        kernel = self.gauss_kernel(size, sigma, c_i)
        var = tf.Variable(tf.convert_to_tensor(kernel), name=name)
        return var
    @layer
    def smoother(self, input, name='gaussian_heatMat'):
        # Get the number of channels in the input
        c_i = input.get_shape().as_list()[3]
        # Convolution for a given input and kernel
        convolve = lambda i, k: tf.nn.depthwise_conv2d(i, k, [1, 1, 1, 1], padding='SAME')
        with tf.variable_scope(name) as scope:
            kernel = self.make_gauss_var('gauss_weight', 25, 3.0, c_i)#filter_size=25,sigma=3.0
            output = convolve(input, kernel)
        return output
I have errors in parsing to network from uff as
[TensorRT] ERROR: gaussian_heatMat/depthwise: kernel weights has count 11875 but 7796358 was expected
[TensorRT] ERROR: gaussian_heatMat/depthwise: count of 11875 weights in kernel, but kernel dimensions (25, 25) with 1459200 input channels, 19 output channels and 19 groups were specified.
[TensorRT] ERROR: UffParser: Parser error: MarkOutput_0: Order size is not matching the number dimensions of TensorRT
11875 = 252519 so that is kernel. Why 7796358 was expected? Don’t under the other errors as well.
