Derived class not seeing protected Members C++ Header file called by *.cu file
The following is the source code relevant to my problem. My issue is that, on compile, I generate 3 errors, all of which say that a corresponding variable is undefined. I am wondering what could be causing this. I’ve checked over the code several times but all seems to be in place. I can upload relevant parts of the Makefile as well, or of the *.cu file utilizing the header file.
template <class T>
	class slave_object
	protected:
		size_t length;
		T* cpu_object;
		T* gpu_object;
	public:
		slave_object(T* master, size_t len = 1)
			length = len;
			cpu_object = master;
			gpu_object = 0;
		virtual ~slave_object()
			release();
		void release()
			if (gpu_object)
				cudaFree(gpu_object);
				gpu_object = 0;
		void update()
			if (!gpu_object)
				cudaMalloc((void**) &gpu_object, sizeof(T) * length);
			cudaMemcpy(gpu_object, cpu_object, sizeof(T) * length,
				   cudaMemcpyHostToDevice);
		operator T* ()
			if (!gpu_object) update();
			return gpu_object;
	template <class T>
	class synchronized_object : public slave_object<T>
	public:
		synchronized_object(T* co, size_t len = 1) :
		slave_object<T>(co, len)
		virtual ~synchronized_object()
			synchronize();
		void synchronize()
			cudaMemcpy(cpu_object, gpu_object, sizeof(T) * length,
			   cudaMemcpyDeviceToHost);
There is no error in this part of code. But I don’t know what is your compiler. I compiled it successfully with VS2008 plus CUDA3.0beta. You may try to clean all the intermediate files and recompile it.
I just wanted to let everyone know that I’ve [SOLVED] the issue by placing this-> in front of each variable I was using from the base class. Idk why that isn’t assumed when using it thru a *.cu file, but it worked.
