I am able to run the deepstream-test1-rtsp-out so I guess the error was caused by not having a display. Is this possible?
Now, how can I fix the setup issue in the deepstream-triton?
maybe, since you are running on dGPU platform, you can modify the source code to change the sink from eglsink to fakesink and try again
I will try. How can I fix the build setup with the triton container? This one Deserialize engine failed because file path: .../resnet10.caffemodel_b1_gpu0_int8.engine open error - #20 by mfoglio
x86 + dGPU + Triton docker ?
Yes, I am using an EC2 with Tesla T4, Intel I-7
doesn’t this work for you?
Hi @mchi . Unfortunately it does not work. See here: Deserialize engine failed because file path: .../resnet10.caffemodel_b1_gpu0_int8.engine open error - #20 by mfoglio
Hi @mfoglio,
Looks like the dockerfile you wrote also expects a manual input:
There are 3 choices for the alternative python3 (providing /usr/bin/python3).
Selection Path Priority Status
0 /usr/bin/python3.8 3 auto mode
1 /usr/bin/python3.6 1 manual mode
2 /usr/bin/python3.6m 2 manual mode
3 /usr/bin/python3.8 3 manual mode
Press to keep the current choice[*], or type selection number:
Can you please try the steps suggested manually without a dockerfile?
Please let me know what happens.
Hello @rpaliwal_nvidia , I have the same issue. The manual input seems to be requested by some step within the docker_python_setup.sh
Sure. Here they are:
ubuntu@ip-x-x-x-x:~$ sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix --cap-add=SYS_PTRACE --security-opt seccomp=unconfined --device /dev/video0 --privileged nvcr.io/nvidia/deepstream:6.0-triton
DeepStreamSDK 6.0.0
*** LICENSE AGREEMENT ***
By using this software you agree to fully comply with the terms and conditions
of the License Agreement. The License Agreement is located at
/opt/nvidia/deepstream/deepstream/LicenseAgreement.pdf. If you do not agree
to the terms and conditions of the License Agreement do not use the software.
== Triton Inference Server ==
NVIDIA Release 21.08 (build 26170506)
Copyright (c) 2018-2021, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
find: File system loop detected; '/usr/bin/X11' is part of the same file system loop as '/usr/bin'.
ERROR: Detected NVIDIA Tesla K80 GPU, which is not supported by this container
ERROR: No supported GPU(s) detected to run this container
root@ip-x-x-x-x:/opt/nvidia/deepstream/deepstream-6.0#
root@ip-x-x-x-x:/opt/nvidia/deepstream/deepstream-6.0# sh docker_python_setup.sh
Reading package lists... Done
Building dependency tree
software-properties-common is already the newest version (0.98.9.5).
0 upgraded, 0 newly installed, 0 to remove and 63 not upgraded.
Ign:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 InRelease
Get:2 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal InRelease [18.1 kB]
Ign:3 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 InRelease
Get:4 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 Release [696 B]
Hit:5 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 Release
Get:6 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 Release.gpg [836 B]
Hit:7 http://archive.ubuntu.com/ubuntu focal InRelease
Get:8 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:9 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:11 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 Packages [515 kB]
Get:12 http://archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
Get:13 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal/main amd64 Packages [26.3 kB]
Get:14 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [30.1 kB]
Get:15 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [726 kB]
Get:16 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [1099 kB]
Get:17 http://security.ubuntu.com/ubuntu focal-security/main amd64 Packages [1329 kB]
Get:18 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages [821 kB]
Get:19 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1744 kB]
Get:20 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [784 kB]
Get:21 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [33.6 kB]
Get:22 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages [21.7 kB]
Get:23 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 Packages [50.0 kB]
Fetched 7535 kB in 2s (3537 kB/s)
Ign:2 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 InRelease
Hit:3 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 Release
Hit:4 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:5 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:6 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal InRelease
Hit:7 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 Release
Hit:8 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:9 http://archive.ubuntu.com/ubuntu focal-backports InRelease
The following additional packages will be installed:
libpython3.6-minimal libpython3.6-stdlib python3.6-minimal
Suggested packages:
python3.6-venv python3.6-doc binfmt-support
The following NEW packages will be installed:
libpython3.6-minimal libpython3.6-stdlib python3.6 python3.6-minimal
0 upgraded, 4 newly installed, 0 to remove and 118 not upgraded.
Need to get 4629 kB of archives.
After this operation, 24.1 MB of additional disk space will be used.
Get:1 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal/main amd64 libpython3.6-minimal amd64 3.6.15-1+focal1 [577 kB]
Get:2 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal/main amd64 python3.6-minimal amd64 3.6.15-1+focal1 [1589 kB]
Get:3 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal/main amd64 libpython3.6-stdlib amd64 3.6.15-1+focal1 [2215 kB]
Get:4 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal/main amd64 python3.6 amd64 3.6.15-1+focal1 [249 kB]
Fetched 4629 kB in 3s (1800 kB/s)
Selecting previously unselected package libpython3.6-minimal:amd64.
(Reading database ... 69896 files and directories currently installed.)
Preparing to unpack .../libpython3.6-minimal_3.6.15-1+focal1_amd64.deb ...
Progress: [ 0%] [......................................................................................................................................................]
Unpacking libpython3.6-minimal:amd64 (3.6.15-1+focal1) .................................................................................................................]
Selecting previously unselected package python3.6-minimal...............................................................................................................]
Preparing to unpack .../python3.6-minimal_3.6.15-1+focal1_amd64.deb ...
Unpacking python3.6-minimal (3.6.15-1+focal1) ..........................................................................................................................]
Selecting previously unselected package libpython3.6-stdlib:amd64.......................................................................................................]
Preparing to unpack .../libpython3.6-stdlib_3.6.15-1+focal1_amd64.deb ...
Unpacking libpython3.6-stdlib:amd64 (3.6.15-1+focal1) ...#####..........................................................................................................]
Selecting previously unselected package python3.6.####################..................................................................................................]
Preparing to unpack .../python3.6_3.6.15-1+focal1_amd64.deb ...
Unpacking python3.6 (3.6.15-1+focal1) ...######################################.........................................................................................]
Setting up libpython3.6-minimal:amd64 (3.6.15-1+focal1) ...#############################................................................................................]
Progress: [ 53%] [###############################################################################.......................................................................]
Setting up python3.6-minimal (3.6.15-1+focal1) ...########################################################..............................................................]
Progress: [ 65%] [#################################################################################################.....................................................]
Setting up libpython3.6-stdlib:amd64 (3.6.15-1+focal1) ...#################################################################.............................................]
Progress: [ 76%] [##################################################################################################################....................................]
Setting up python3.6 (3.6.15-1+focal1) ...###################################################################################################...........................]
Progress: [ 88%] [####################################################################################################################################..................]
Processing triggers for mime-support (3.64ubuntu1) ...#########################################################################################################.........]
libpython3.6
0 upgraded, 1 newly installed, 0 to remove and 118 not upgraded.
Need to get 1570 kB of archives.
After this operation, 4778 kB of additional disk space will be used.
Get:1 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal/main amd64 libpython3.6 amd64 3.6.15-1+focal1 [1570 kB]
Fetched 1570 kB in 1s (2231 kB/s)
Selecting previously unselected package libpython3.6:amd64.
(Reading database ... 70730 files and directories currently installed.)
Preparing to unpack .../libpython3.6_3.6.15-1+focal1_amd64.deb ...
Unpacking libpython3.6:amd64 (3.6.15-1+focal1) .........................................................................................................................]
Setting up libpython3.6:amd64 (3.6.15-1+focal1) ...###########################..........................................................................................]
Progress: [ 60%] [##########################################################################################............................................................]
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...####################################################################################..............................]
The following packages were automatically installed and are no longer required:
bubblewrap distro-info-data fuse gir1.2-packagekitglib-1.0 libappstream4 libfuse2 liblmdb0 libpackagekit-glib2-18 libpolkit-agent-1-0 libpolkit-gobject-1-0 libstemmer0d
libyaml-0-2 lsb-release packagekit policykit-1 python-apt-common python3-apt python3-certifi python3-chardet python3-dbus python3-idna python3-requests
python3-requests-unixsocket python3-six python3-urllib3 xdg-desktop-portal
Use 'apt autoremove' to remove them.
The following packages will be REMOVED:
libglib2.0-tests python3-dbusmock python3-gi python3-software-properties software-properties-common
0 upgraded, 0 newly installed, 5 to remove and 116 not upgraded.
After this operation, 11.8 MB disk space will be freed.
(Reading database ... 70737 files and directories currently installed.)
Removing libglib2.0-tests (2.64.6-1~ubuntu20.04.4) ...
Progress: [ 9%] [#############.........................................................................................................................................]
Removing python3-dbusmock (0.19-1) ...#######...........................................................................................................................]
Progress: [ 27%] [########################################..............................................................................................................]
Removing software-properties-common (0.98.9.5) ...######################................................................................................................]
Progress: [ 45%] [####################################################################..................................................................................]
Removing python3-software-properties (0.98.9.5) ...################################################.....................................................................]
Progress: [ 64%] [###############################################################################################.......................................................]
Removing python3-gi (3.36.0-1) ...#############################################################################################.........................................]
Progress: [ 82%] [##########################################################################################################################............................]
Processing triggers for dbus (1.12.16-2ubuntu2.1) ...#####################################################################################################..............]
--2021-12-07 16:59:30-- http://mirrors.edge.kernel.org/ubuntu/pool/main/p/pygobject/python3-gi_3.26.1-2ubuntu1_amd64.deb
Resolving mirrors.edge.kernel.org (mirrors.edge.kernel.org)... 147.75.197.195, 2604:1380:1:3600::1
Connecting to mirrors.edge.kernel.org (mirrors.edge.kernel.org)|147.75.197.195|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 153080 (149K) [application/octet-stream]
Saving to: 'python3-gi_3.26.1-2ubuntu1_amd64.deb'
python3-gi_3.26.1-2ubuntu1_amd64.deb 100%[========================================================================================>] 149.49K --.-KB/s in 0.03s
2021-12-07 16:59:30 (5.10 MB/s) - 'python3-gi_3.26.1-2ubuntu1_amd64.deb' saved [153080/153080]
Selecting previously unselected package python3-gi.
(Reading database ... 69764 files and directories currently installed.)
Preparing to unpack python3-gi_3.26.1-2ubuntu1_amd64.deb ...
Unpacking python3-gi (3.26.1-2ubuntu1) ...
dpkg: dependency problems prevent configuration of python3-gi:
python3-gi depends on python3 (<< 3.7); however:
Version of python3 on system is 3.8.2-0ubuntu2.
python3-gi depends on libffi6 (>= 3.0.4); however:
Package libffi6 is not installed.
libgirepository-1.0-1:amd64 (1.64.1-1~ubuntu20.04.1) breaks python3-gi (<< 3.34.0-4~) and is installed.
Version of python3-gi to be configured is 3.26.1-2ubuntu1.
dpkg: error processing package python3-gi (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
python3-gi
update-alternatives: using /usr/bin/python3.6 to provide /usr/bin/python3 (python3) in auto mode
update-alternatives: using /usr/bin/python3.6m to provide /usr/bin/python3 (python3) in auto mode
update-alternatives: using /usr/bin/python3.8 to provide /usr/bin/python3 (python3) in auto mode
* 0 /usr/bin/python3.8 3 auto mode
Press <enter> to keep the current choice[*], or type selection number: update-alternatives: using /usr/bin/python3.6m to provide /usr/bin/python3 (python3) in manual mode
Collecting numpy
Downloading numpy-1.19.5-cp36-cp36m-manylinux2010_x86_64.whl (14.8 MB)
|################################| 14.8 MB 20.6 MB/s
Installing collected packages: numpy
Successfully installed numpy-1.19.5
Collecting opencv-python
Downloading opencv_python-4.5.4.60-cp36-cp36m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (60.3 MB)
|################################| 60.3 MB 24.9 MB/s
Requirement already satisfied: numpy>=1.13.3 in /usr/local/lib/python3.6/dist-packages (from opencv-python) (1.19.5)
Installing collected packages: opencv-python
Successfully installed opencv-python-4.5.4.60
root@ip-x-x-x-x:/opt/nvidia/deepstream/deepstream-6.0# apt install python3-gi python3-gst-1.0 python-gi-dev git python3 python3-pip cmake g++ build-essential libglib2.0-dev python3-dev python3.6-dev libglib2.0-dev-bin python-gi-dev libtool m4 autoconf automake
autoconf is already the newest version (2.69-11.1).
automake is already the newest version (1:1.16.1-4ubuntu6).
automake set to manually installed.
cmake is already the newest version (3.16.3-1ubuntu1).
g++ is already the newest version (4:9.3.0-1ubuntu2).
g++ set to manually installed.
libtool is already the newest version (2.4.6-14).
m4 is already the newest version (1.4.18-4).
m4 set to manually installed.
python3 is already the newest version (3.8.2-0ubuntu2).
build-essential is already the newest version (12.8ubuntu1.1).
git is already the newest version (1:2.25.1-1ubuntu3.2).
libglib2.0-dev is already the newest version (2.64.6-1~ubuntu20.04.4).
libglib2.0-dev-bin is already the newest version (2.64.6-1~ubuntu20.04.4).
python3-pip is already the newest version (20.0.2-5ubuntu1.6).
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
python3-dev : Depends: libpython3-dev (= 3.8.2-0ubuntu2) but it is not going to be installed
Depends: python3.8-dev (>= 3.8.2-1~) but it is not going to be installed
python3.6-dev : Depends: libpython3.6-dev (= 3.6.15-1+focal1) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
hi @mfoglio ,
Did you try running the suggested **apt --fix-broken install**
then?
Also, try to uninstall python3.6-dev and make sure your default python points to 3.8
Let me know what happens.
The --fix-broken
does not help:
root@ip-172-31-20-37:/opt/nvidia/deepstream/deepstream-6.0# apt install --fix-broken python3-gi python3-gst-1.0 python-gi-dev git python3 python3-pip cmake g++ build-essential libglib2.0-dev python3-dev python3.6-dev libglib2.0-dev-bin python-gi-dev libtool m4 autoconf automake
There’s no python3.6-dev
to remove:
root@ip-172-31-20-37:/opt/nvidia/deepstream/deepstream-6.0# apt remove python3.6-dev
E: Unable to locate package python3.6-dev
E: Couldn't find any package by glob 'python3.6-dev'
How do I change the default Python version? I tried with alias python3=/usr/bin/python3.8
but it doesn’t make any difference. The problem seems to be with apt.
Have you recently tried to run yours instruction? Can you reproduce the error?
You only need to run this command, don’t include other package names in there.
Great! This fixes the apt install, thanks! How can I set default pip and python to 3.6? Is a simple alias sufficient?
Now I have the following issue. From python3.8 I can import pyds
but not gi
. And the opposite from python3.6.
To reproduce you can use:
FROM nvcr.io/nvidia/deepstream:6.0-triton
ENV GIT_SSL_NO_VERIFY=1
RUN sh docker_python_setup.sh
RUN update-alternatives --set python3 /usr/bin/python3.6m
RUN apt install --fix-broken -y
RUN apt -y install python3-gi python3-gst-1.0 python-gi-dev git python3 python3-pip cmake g++ build-essential \
RUN cd /opt/nvidia/deepstream/deepstream-6.0/sources/apps && \
git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
RUN cd /opt/nvidia/deepstream/deepstream-6.0/sources/apps/deepstream_python_apps && \
git submodule update --init
RUN cd /opt/nvidia/deepstream/deepstream-6.0/sources/apps/deepstream_python_apps/3rdparty/gst-python/ && \
./autogen.sh PYTHON=/usr/bin/python3.6m && \
make && \
make install
RUN pip3 install --upgrade pip
RUN cd /opt/nvidia/deepstream/deepstream-6.0/sources/apps/deepstream_python_apps/bindings && \
mkdir build && \
cd build && \
cmake -DPYTHON_MAJOR_VERSION=3 -DPYTHON_MINOR_VERSION=6 -DPIP_PLATFORM=linux_x86_64 -DDS_PATH=/opt/nvidia/deepstream/deepstream-6.0 .. && \
make && \
pip3 install pyds-1.1.0-py3-none-linux_x86_64.whl
mv apps/* ./
RUN pip3 install numpy opencv-python
# RTSP
RUN apt update && \
apt install -y python3-gi python3-dev python3-gst-1.0
RUN apt update && \
apt install -y libgstrtspserver-1.0-0 gstreamer1.0-rtsp && \
apt install -y libgirepository1.0-dev && \
apt-get install -y gobject-introspection gir1.2-gst-rtsp-server-1.0
Then start the container and run:
docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix -v /home/ubuntu/pycharm/projects/fususcore-ai-detector-nvidia/etc/local:/shared --cap-add=SYS_PTRACE --security-opt seccomp=unconfined --device /dev/video0 --privileged --expose 8554 deepstream-custom bash
root@ip-172-31-20-37:/src# python3.6
Python 3.6.15 (default, Sep 10 2021, 00:26:58)
[GCC 9.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import gi
File "<stdin>", line 1, in <module>
File "/usr/lib/python3/dist-packages/gi/__init__.py", line 42, in <module>
from . import _gi
ImportError: cannot import name '_gi'
>>> import pyds
root@ip-172-31-20-37:/src# python3.8
Python 3.8.10 (default, Sep 28 2021, 16:10:42)
>>> import gi
>>> import pyds
ModuleNotFoundError: No module named 'pyds'
Should I use python3.6, python3.6m, or python3.8?
hi @mfoglio ,
Good to see that your apt install was fixed.
Since the triton docker is based on Ubuntu 20.04, its best to use python3.8 on it.
Please don’t install any 3.6 related packages, those could interfere with the environment.
Yes, we can consider it solved. Thanks!
