Designing a Custom 40-pin Expansion Header on Jetson Thor Platform
Dear NVIDIA Team,
We are currently evaluating a new hardware design based on the Jetson platform.
While the Jetson AGX Orin and Orin NX/Nano carrier boards natively feature a standard 40-pin expansion header, we noticed that the Jetson Thor Developer Kit (Evaluation Board) does not include this 40-pin interface.
For our custom carrier board design, we are exploring the possibility of multiplexing or routing unused pins from the Jetson Thor module to form an equivalent 40-pin expansion header.
Could you please assist us with the following technical questions?
  1. Pin Multiplexing Capability: Is it feasible to route the unused GPIO/functional pins on the Jetson Thor module to replicate the standard 40-pin header pinout?
  2. Software Tool Support:Does the Jetson Expansion Header Tool (or the updated Jetson Config/Pinmux spreadsheet for Thor) support this customized 40-pin configuration? If so, what is the recommended workflow to apply these changes?
Any documentation, Pinmux spreadsheets, or reference design guidelines regarding the Jetson Thor I/O configuration would be highly appreciated.
I think using unused GPIO is possible but our tool may not support it directly but you may need to configure pinmux though spreadsheet.
What’s your primary goal? Maintaining compatibility with existing 40-pin HATs or other accessories?
Dear WayneWWW,
I am currently working on the Jetson Thor platform. Regarding the Pinmux modification, I am already familiar with the workflow using the Excel configuration sheet.
However, since our reference carrier board design does not pre-configure the 40-pin Expansion Header by default, I would like to implement or enable jetson-io.py support for the 40-pin Expansion Header specifically on the Jetson Thor platform.
Dear carterlngstn,
