Detail of parameters of DeepSORT, on DeepStream6.0
Hello.
**• Hardware Platform (Jetson / GPU): jetson
**• DeepStream Version: 6.0
**• JetPack Version (valid for Jetson only): 4.6
**• Issue Type( questions, new requirements, bugs): questions
I have been trying to use DeepSORT with NvMultiObjectTracker, pre-implemented library, on Deepstream 6.0.
And I checked out the default yml file of it provided by deepstream and its document on web site.
But I can’t understand some parameters.
So I would like to know about the detail of its parameters, especially below.
First,
  • stateEstimatorType
  • reidType
    For these params, I understood DUMMY means that the algorithm won’t be used to track objects.
    For example, if I set stateEstimatorType=0, only ReID will be used. Is this correct?
Second,
  • reidHistorySize
    If frames of the number of set size passed, the oldest feature vector of each target tracker is deleted even if the frame that a detector can’t find any object is included in these frames?
    For example, if I set this to 2 and 3 frames have passed since tracking started, first feature vector of each tracker object will be deleted. But how about the situation where a detector can’t find any object at a frame out of 3 frames? This means each tracker object has only 2 features after passing 3 frames. In this situation, the features of each object won’t be erased. Is this correct?
Thank you,
Below is what I can share to help you understand it. Hope you can change those parameters and have a try the impact of those parameters.
Gst-nvtracker — DeepStream 6.1 Release documentation (nvidia.com)
/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_tracker_DeepSORT.yml
@kesong
Thank you for your reply.
I am reading the document but I can’t figure out in some ways.
Can I ask you if I set stateEstimatorType to 0, which means “DUMMY”, how this algorithm calculate mahalanobis distance?
Thank you.
SIMPLE and REGULAR use Kalman Filter for state estimation. DUMMY will do easy state update.
stateEstimatorType: 2 # the type of state estimator among { DUMMY=0, SIMPLE=1, REGULAR=2 }
