Hi everyone,
The TLT link (https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/text/creating_experiment_spec.html#cost-function) suggests that the parameters for the cost function remain unchanged. However, it seems that the parameters are specific only to car, cyclist, and pedestrian classes.
I am training a PeopleNet model on my custom dataset with only person and face.
I extracted the occurrences of each classes in my whole training and validation data and the number of person class is almost THRICE the number of face class. Is it correct if I set class weight of face to be 3 and person to be 1?
How do we tweak coverage_foreground_weight, and the objectives (cov and bbox) initial and target weight? What do these initial and target weight mean? I am getting 70+ precision on face but terrible precision of about low 20s on person.
random_seed: 42
model_config {
pretrained_model_file: “/workspace/Script/Pretrained_Weights/resnet18_peoplenet.tlt”
arch: “resnet”
num_layers: 18
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
dataset_config {
data_sources: {
tfrecords_path: “/workspace/Script/TFRecords/*”
image_directory_path: “/workspace/Script/Data/”
image_extension: “jpg”
target_class_mapping {
key: “person”
value: “person”
key: “bag”
value: “bag”
key: “face”
value: “face”
validation_fold: 0
training_config {
batch_size_per_gpu: 16
num_epochs: 120
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 0.0005
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-09
optimizer {
adam {
epsilon: 9.9e-09
beta1: 0.9
beta2: 0.999
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 5
bbox_rasterizer_config {
target_class_config {
key: “person”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
bbox_min_radius: 1.0
key: “bag”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: “face”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.400000154972
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 544
crop_right: 960
crop_bottom: 544
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.5
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config{
target_class_config{
key: “person”
value: {
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.001
dbscan_min_samples: 0.05
minimum_bounding_box_height: 4
key: “bag”
value: {
clustering_config {
dbscan_eps: 0.15
key: “face”
value: {
clustering_config {
dbscan_eps: 0.15
minimum_bounding_box_height: 2
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 20
minimum_detection_ground_truth_overlap {
key: “bag”
value: 0.5
key: “face”
value: 0.5
key: “person”
value: 0.5
evaluation_box_config {
key: “bag”
value {
minimum_height: 40
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
key: “face”
value {
minimum_height: 2
minimum_width: 2
maximum_width: 9999
key: “person”
value {
minimum_height: 40
minimum_width: 4
maximum_width: 9999
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 3.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
