DetectBot hunts Candy whit WiFi keyboard control
Hello, I’ve made a robot that use trained custom detection model called ‘‘CandyNet’’ to follow objects.
Due to time limitations the build is in Alpha state so it works but many parameters need tweaking.
Full documentation on https://github.com/PixzlPlot/DetectBot
Sounds interesting, however your GitHub link above is 404. Would you mind editing your post to correct it?
Excuse me, now it could be solved
Hi PxzlPlot, thanks for sharing - nice work! I really like that tank chassis that you used for your robot as well.
