Used exact same reference , its not like everytime its blurred but 3 out of 5 times image is really blurred .
It is more like an issue that the h264 stream is not received completely and certain macro blocks cannot be correctly decoded. Suggest you save the h264 stream to a file:
rtspsrc ! rtph264depay ! h264parse ! video/x-h264,stream-format=byte-stream ! filesink location=dump.h264
And check validness of the steam via ffmpeg or JM decoder. You can also try deepstream-test1.
We don’t have similar issues reported on DeepStream SDK 5.0 DP, but this actually is not a stable release. You may wait for DeepStream SDK 5.0 GA.
How does one check the validness of the stream? What are the commands?
