Hello everyone, I’m encountering a “Detected Stale NavMesh” error while using the newly introduced SDG extension for Isaac Sim 4.5.0.
When I try to run the simulation the error spawns, here are the details about the error:
As per the Traceback, the error details says it’s a TypeError and appears when loading characters from a config file, it seems related to the construction of a carb.Float3 object.
More specifically, spawn_location variable passed to carb.Float3() is None, which triggers the exception and this happens specifically in randomizer.py during a call to get_random_position().
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
1. carb._carb.Float3()
2. carb._carb.Float3(arg0: float, arg1: float, arg2: float)
3. carb._carb.Float3(arg0: sequence)
Invoked with: None
Has anyone else encountered this? Any suggestions on how to handle or debug this issue?
Thanks in advance!
