• Hardware Platform: GPU
• DeepStream Version: 5.0.0
• TensorRT Version: 7.0.0.11
• NVIDIA GPU Driver Version (valid for GPU only): 460.32.03
I have a case where my detector finds a bbox which’s top value is less than zero. It gets filtered out in attach_metadata_detector
. The value used to it is filter_params.roiTopOffset
which is defined as guint
and corresponds to roi-top-offset
in the config file. However it seems to be outdated as I hit this guy: Unknown or legacy key specified 'roi-top-offset' for group [property]
. Is it save to just remove that check or what is the proposed way to handle those values?
