• DeepStream Version 5.0
• JetPack Version 4.4
• Issue Type: question
Hi, I’m having a problem with adding stereo camera as a source for deepstreamer. Camera output is MJPEG with 1 frame for two cameras. I need to crop one of them and sink to nvinfer plugin.
Camera params:
Camera
v4l2-ctl -d /dev/video1 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.033s (30.000 fps)
This is working sample of cropping pipeline
gst-launch-1.0 v4l2src device=/dev/video1 io-mode=2 blocksize=800000 ! image/jpeg, width=2560, height=960 ! nvjpegdec ! "video/x-raw, format=I420, framerate=30/1" ! nvvidconv interpolation-method=0 ! "video/x-raw, width=2560, height=960, format=I420" ! queue ! nvvidconv left=0 right=1280 top=120 bottom=840 ! "video/x-raw(memory:NVMM), width=1280, height=720, pixel-aspect-ratio=1/1, format=(string)I420" ! nvegltransform ! nveglglessink
Working pipeline with added plugins for inference and picture saving for mp4 video
gst-launch-1.0 filesrc location= /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/config_infer_primary_facedetectir.txt batch-size=1 unique-id=1 ! nvvideoconvert ! dsexample full-frame=0 ! nvdsosd ! nvegltransform ! nveglglessink
But when I try to capture from camera I fail
gst-launch-1.0 v4l2src device=/dev/video1 io-mode=2 blocksize=800000 ! image/jpeg, width=2560, height=960 ! nvjpegdec DeepStream=1 ! "video/x-raw, format=I420, framerate=30/1" ! nvvidconv interpolation-method=0 ! "video/x-raw, width=2560, height=960, format=NV12" ! queue ! nvvidconv left=0 right=1280 top=120 bottom=840 ! "video/x-raw(memory:NVMM), width=1280, height=720, pixel-aspect-ratio=1/1, format=(string)NV12" ! queue ! m.sink_0 nvstreammux name=m batch-size=1 batched-push-timeout=40000 width=1280 height=720 live-source=TRUE ! queue ! nvvidconv ! queue ! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/config_infer_primary_facedetectir.txt batch-size=1 unique-id=1 ! nvvideoconvert ! dsexample full-frame=0 ! nvdsosd ! nvegltransform ! nveglglessink
Output is:
Summary
Using winsys: x11
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:04.868973002 19081 0x558dbfcd50 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/tlt_pretrained_models/facedetectir/resnet18_facedetectir_pruned.etlt_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x240x384
1 OUTPUT kFLOAT output_bbox/BiasAdd 4x15x24
2 OUTPUT kFLOAT output_cov/Sigmoid 1x15x24
0:00:04.869113943 19081 0x558dbfcd50 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/tlt_pretrained_models/facedetectir/resnet18_facedetectir_pruned.etlt_b1_gpu0_fp16.engine
0:00:04.880207400 19081 0x558dbfcd50 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/config_infer_primary_facedetectir.txt sucessfully
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
Caught SIGSEGV
^CSpinning. Please run 'gdb gst-launch-1.0 19081' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
handling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:03.796977163
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
