OK great! You will need to re-organize the files from the Roboflow to be like CVAT - CVAT automatically exports close to Pascal VOC format.
- Annotations/ # put all of your XML files here
- ImageSets/Main/ # make *.txt files with a list of image ID's
- JPEGImages/ # put all of your images here
- labels.txt # create this with your class ID's
Inside ImageSets/Main, there should be the following files:
test.txt train.txt trainval.txt val.txt
Each of these contains the list of imageID’s used for train/val/test. It is one imageID per line Iwithout the .jpg extension). You can typically make a script to create these txt files for you. A snippet of one of mine looks like:
