I successfully downloaded and compiled the deep vision tutorial from here:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/building-repo-2.md
i am using the raspberry pi camera and the hardware works ok
./detectnet-camera facenet
detectnet-camera
args (2): 0 [./detectnet-camera] 1 [facenet]
[gstreamer] initialized gstreamer, version 1.14.1.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVCAMERA
[gstreamer] gstCamera pipeline string:
nvcamerasrc fpsRange="30.0 30.0" ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera failed to create pipeline
[gstreamer] (no element "nvcamerasrc")
[gstreamer] failed to init gstCamera (GST_SOURCE_NVCAMERA)
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVARGUS
nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_NVARGUS
detectnet-camera: successfully initialized video device
width: 1280
height: 720
depth: 12 (bpp)
detectNet -- loading detection network model from:
-- prototxt networks/facenet-120/deploy.prototxt
-- model networks/facenet-120/snapshot_iter_24000.caffemodel
-- input_blob 'data'
-- output_cvg 'coverage'
-- output_bbox 'bboxes'
-- mean_pixel 0.000000
-- class_labels networks/facenet-120/class_labels.txt
-- threshold 0.500000
-- batch_size 2
[TRT] TensorRT version 5.0.6
[TRT] detected model format - caffe (extension '.caffemodel')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file networks/facenet-120/snapshot_iter_24000.caffemodel.2.1.GPU.FP16.engine
[TRT] cache file not found, profiling network model on device GPU
[TRT] device GPU, loading networks/facenet-120/deploy.prototxt networks/facenet-120/snapshot_iter_24000.caffemodel
[TRT] retrieved Output tensor "coverage": 1x28x28
[TRT] retrieved Output tensor "bboxes": 4x28x28
[TRT] retrieved Input tensor "data": 3x450x450
[TRT] device GPU, configuring CUDA engine
[TRT] device GPU, building FP16: ON
[TRT] device GPU, building INT8: OFF
[TRT] device GPU, building CUDA engine (this may take a few minutes the first time a network is loaded)
after about 15 minutes it then puts up a window and captures two frames and then freezes.
And in terminal i see lots of this:
detectnet-camera: failed to capture frame
detectnet-camera: failed to convert from NV12 to RGBA
detectNet::Detect( 0x(nil), 1280, 720 ) -> invalid parameters
[cuda] cudaNormalizeRGBA((float4*)imgRGBA, make_float2(0.0f, 255.0f), (float4*)imgRGBA, make_float2(0.0f, 1.0f), camera->GetWidth(), camera->GetHeight())
[cuda] invalid device pointer (error 17) (hex 0x11)
[cuda] /home/stefan/jetson-inference/detectnet-camera/detectnet-camera.cpp:247
