How to find the execution time of the model.
And detectnet model uses some labels by default. Is it possible to add new labels. If so how can we add those
You can get the detailed execution time with our trtexec app:
/usr/src/tensorrt/bin/trtexec --deploy=[your/prototxt]
To add a new label, indicating you want the model to recognize one more class type.
So you will need to retrain the detectnet with the dataset including the new object image.
Here is a training tutorial of ResNet-18 and SSD-Mobilenet for your reference:
<img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/deep-vision-header.jpg" width="100%">
<p align="right"><sup><a href="depthnet.md">Back</a> | <a href="pytorch-cat-dog.md">Next</a> | </sup><a href="../README.md#hello-ai-world"><sup>Contents</sup></a>
<br/>
<sup>Transfer Learning</sup></s></p>
# Transfer Learning with PyTorch
Transfer learning is a technique for re-training a DNN model on a new dataset, which takes less time than training a network from scratch. With transfer learning, the weights of a pre-trained model are fine-tuned to classify a customized dataset. In these examples, we'll be using the <a href="https://arxiv.org/abs/1512.03385">ResNet-18</a> and [SSD-Mobilenet](pytorch-ssd.md) networks, although you can experiment with other networks too.
<p align="center"><a href="https://arxiv.org/abs/1512.03385"><img src="https://github.com/dusty-nv/jetson-inference/raw/python/docs/images/pytorch-resnet-18.png" width="600"></a></p>
Although training is typically performed on a PC, server, or cloud instance with discrete GPU(s) due to the often large datasets used and the associated computational demands, by using transfer learning we're able to re-train various networks onboard Jetson to get started with training and deploying our own DNN models.
<a href=https://pytorch.org/>PyTorch</a> is the machine learning framework that we'll be using, and example datasets along with training scripts are provided to use below, in addition to a camera-based tool for collecting and labeling your own training datasets.
## Installing PyTorch
If you are [Running the Docker Container](aux-docker.md) or optionally chose to install PyTorch back when you [Built the Project](building-repo-2.md#installing-pytorch), it should already be installed on your Jetson to use. Otherwise, if you aren't using the container and want to proceed with transfer learning, you can install it now:
``` bash
This file has been truncated. show original
