I am doing a training test with images of types of apples, in the response of the system I am getting the squares mounted with the label.
How can I improve that answer?
Do you want to merge the bounding box?
If yes, you can check the NMS algorithm:
Yes, I want to stabilize the detection and that it recognizes with 1 single box and not 3 as shown in the attached image.
In what exact part of the code should it intervene?
Hi @agarcesc7, try decreasing the clustering threshold on this line in jetson-inference/c/detectNet.h
By default the threshold is .75 (meaning the overlapping area needs to be >= 75% of the total area of the bounding box to be merged). So if you decrease that, it will more aggressively merge the bounding boxes.
After you change it, re-compile / re-install the code:
cd /path/to/your/jetson-inference/build
cmake ../
make
sudo make install
Hi Dusty. Thank you.
It worked! Is there an option to leave only the marked border and the fill without color?
Hi @agarcesc7, sorry there isn’t the option for that. You could disable the overlay entirely and draw your own bounding boxes (i.e. with openCV or similar)
