Possibly you are using an incompatible type of CPU that the TensorFlow package in TLT container does not support. What is the CPU info in your host PC?
Referece:
I’m trying to run example detectnet_v2 and facing an Illegal Instruction error when I execute the tlt-train command. I’m running it on RTX 2080 GPU on a Dell R720 server. Here’s the output log:
root@2a9a93f3988b:/workspace# tlt-train detectnet_v2 -e $SPECS_DIR/detectnet_v2_train_resnet18_kitti.txt -r $USER_EXPERIMENT_DIR/experiment_dir_unpruned -k $KEY -n resnet18_detector
Using TensorFlow backend.
[[2548,1],0]: A high-performance Open MPI point-to-point messaging module
was unable to f…
