Detectnet_V2 Training Configuration (nVidia TLT-NGC)
Hi guys!
I am currently training a custom object detection model using resnet-18 and detectnet_v2 for character detection with images size of 842 x 320 pixel.
I inspected that the original detectnet has this one specification configuration:
preprocessing {
	output_image_width: 1248
	output_image_height: 384
	min_bbox_width: 1.0
	min_bbox_height: 1.0
	output_image_channel: 3
Then, I tried to blindly change that preprocessing configuration into this one:
preprocessing {
	output_image_width: 832
	output_image_height: 320
	min_bbox_width: 1.0
, so it could fit our custom dataset.
Is it allowed to train the detectnet_v2 this way, by changing the preprocessing part only?
Or should I use 1248 x 384 pixel and change our images size and its bounding box to match that 1248 x 384 with padding?
Thank you. I would appreciate any ideas.
Best regards,
Jeff
Hi jefflgaol,
You need not to use 1248 x 384 pixel.
Yes, you can change the (output_image_width, output_image_height) to (832,320) or (848,320).
Thank you very much.
Best regards,
Jeff
