d:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\bin\win64\Release>d
eviceQuery.exe
deviceQuery.exe Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “GeForce GT 240M”
CUDA Driver Version: 3.10
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 2
Total amount of global memory: 1034485760 bytes
Number of multiprocessors: 6
Number of cores: 48
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Clock rate: 1.21 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads
can use this device simultaneously)
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 3.10, CUDA Runtime Vers
ion = 3.0, NumDevs = 1, Device = GeForce GT 240M
PASSED
Press to Quit…
