I am trying to use the JetPack 3.2 installer with a TX2 over wireless since my host does not have an ethernet port. I have some hope that it is possible, despite the views on the forums, based on the logic that a local network connection is used to transfer the files and thus should not need to know if wifi or wired option is used. I found one thread where it sounds like an expert admits it might be possible, but not recommended.
…It may work then, but is not as reliable over wireless.
https://devtalk.nvidia.com/default/topic/1023293/how-to-install-jetpack-3-0-by-wireless-network/
My goal is to only install the “drivers” because the CUDA samples on the TX2 are complaining that no driver could be detected. The fact that the CUDA 9 Samples are on the device shows I was able to install some content with a wireless connection. I am hoping someone can understand the logs (I wish I could attach to this message). I noticed some "/dev/null"s but I’m not sure if the log is from only the most recent attempt or all attempts and I ran Jetpack several times, getting further sometimes.
I avoided a flash on this device, and thus did not connect the USB data cable, because I am gunshy after I put a different TX2 device in an unusable state (another thread coming) when attempting to use a different host to flash that device.
I cannot include the logs. If I try, the site is broken. I tried to paste the contents of the log since I cannot find a button to attach a document to the post.
jetpack_debug.log (14 KB)
flash_os_tx2-usb3-vm-wifi.log (179 KB)
