I am not quite sure where to put the command -pxtas-options=-v in the make File. I get the following error:
nvcc fatal : Unknown option ‘pxtas-options’
make: *** [obj//mt19937_ref.cu.o] Error 255
Here is my Makefile. Any help would be greaty appreciated!!
[codebox] ############################################################
Build script for project
Add source files here
EXECUTABLE := evolve_smaller_particles
Cuda source files (compiled with cudacc)
CUFILES := mt19937_ref.cu simpleGL.cu
CCFILES := genmtrand.cpp
USEGLLIB := 1
USEPARAMGL := 0
USEGLUT := 1
Rules and targets
.SUFFIXES : .cu .cu_dbg.o .c_dbg.o .cpp_dbg.o .cu_rel.o .c_rel.o .cpp_rel.o .cubin
Add new SM Versions here as devices with new Compute Capability are released
SM_VERSIONS := sm_10 sm_11 sm_12 sm_13
CUDA_INSTALL_PATH ?= /usr/local/cuda
ifdef cuda-install
CUDA_INSTALL_PATH := $(cuda-install)
endif
detect OS
OSUPPER = $(shell uname -s 2>/dev/null | tr [:lower:] [:upper:])
OSLOWER = $(shell uname -s 2>/dev/null | tr [:upper:] [:lower:])
‘linux’ is output for Linux system, ‘darwin’ for OS X
DARWIN = $(strip $(findstring DARWIN, $(OSUPPER)))
Basic directory setup for SDK
(override directories only if they are not already defined)
SRCDIR ?=
ROOTDIR ?= …/…
ROOTBINDIR ?= .
BINDIR ?= $(ROOTBINDIR)
ROOTOBJDIR ?= obj
LIBDIR := $(ROOTDIR)/lib
COMMONDIR := $(ROOTDIR)/common
MODULEDIR := ./modules/
Compilers
NVCC := $(CUDA_INSTALL_PATH)/bin/nvcc
CXX := g++
CC := gcc
LINK := g++ -fPIC
Includes
INCLUDES += -I. -I$(CUDA_INSTALL_PATH)/include -I$(COMMONDIR)/inc -I./include -I/usr/include/netcdf-3 -I./kernel -I/usr/include/vtk-5.0
architecture flag for cubin build
CUBIN_ARCH_FLAG := -m32
Warning flags
CXXWARN_FLAGS := \
-W -Wall \
-Wimplicit \
-Wswitch \
-Wformat \
-Wchar-subscripts \
-Wparentheses \
-Wmultichar \
-Wtrigraphs \
-Wpointer-arith \
-Wcast-align \
-Wreturn-type \
-Wno-unused-function \
$(SPACE)
CWARN_FLAGS := $(CXXWARN_FLAGS) \
-Wstrict-prototypes \
-Wmissing-prototypes \
-Wmissing-declarations \
-Wnested-externs \
-Wmain \
Compiler-specific flags
NVCCFLAGS := #-keep -pxtas-options=-v
CXXFLAGS := $(CXXWARN_FLAGS) -Wno-deprecated
CFLAGS := $(CWARN_FLAGS)
Common flags
COMMONFLAGS += $(INCLUDES) -DUNIX
Debug/release configuration
ifeq ($(dbg),1)
COMMONFLAGS += -g
NVCCFLAGS += -D_DEBUG
BINSUBDIR :=
LIBSUFFIX := D
else
COMMONFLAGS += -O3
BINSUBDIR :=
LIBSUFFIX :=
NVCCFLAGS += --compiler-options -fno-strict-aliasing
CXXFLAGS += -fno-strict-aliasing
CFLAGS += -fno-strict-aliasing
endif
append optional arch/SM version flags (such as -arch sm_11)
#NVCCFLAGS += $(SMVERSIONFLAGS)
detect if 32 bit or 64 bit system
HP_64 = $(shell uname -m | grep 64)
OpenGL is used or not (if it is used, then it is necessary to include GLEW)
ifeq ($(USEGLLIB),1)
ifneq ($(DARWIN),)
OPENGLLIB := -L/System/Library/Frameworks/OpenGL.framework/Libraries -lGL -lGLU $(COMMONDIR)/lib/$(OSLOWER)/libGLEW.a
else
OPENGLLIB := -lGL -lGLU -lX11 -lXi -lXmu
ifeq “$(strip $(HP_64))” “”
OPENGLLIB += -lGLEW -L/usr/X11R6/lib
else
OPENGLLIB += -lGLEW_x86_64 -L/usr/X11R6/lib64
endif
endif
CUBIN_ARCH_FLAG := -m64
endif
ifeq ($(USEGLUT),1)
ifneq ($(DARWIN),)
OPENGLLIB += -framework GLUT
else
OPENGLLIB += -lglut
endif
endif
ifeq ($(USEPARAMGL),1)
PARAMGLLIB := -lparamgl$(LIBSUFFIX)
endif
ifeq ($(USERENDERCHECKGL),1)
RENDERCHECKGLLIB := -lrendercheckgl$(LIBSUFFIX)
endif
ifeq ($(USECUDPP), 1)
ifeq "$(strip $(HP_64))" ""
CUDPPLIB := -lcudpp
else
CUDPPLIB := -lcudpp64
endif
CUDPPLIB := $(CUDPPLIB)$(LIBSUFFIX)
ifeq ($(emu), 1)
CUDPPLIB := $(CUDPPLIB)_emu
endif
endif
Libs
LIB := -L$(CUDA_INSTALL_PATH)/lib -L$(LIBDIR) -L$(COMMONDIR)/lib/$(OSLOWER)
LIB += -lnetcdf_c++ -lnetcdf -L/usr/lib/netcdf-3 -lgsl -lgslcblas -lcufft
ifeq ($(USEDRVAPI),1)
LIB += -lcuda ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB}
else
LIB += -lcudart ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB}
endif
ifeq ($(USECUFFT),1)
ifeq ($(emu),1)
LIB += -lcufftemu
else
LIB += -lcufft
endif
endif
ifeq ($(USECUBLAS),1)
ifeq ($(emu),1)
LIB += -lcublasemu
else
LIB += -lcublas
endif
endif
Lib/exe configuration
ifneq ($(STATIC_LIB),)
TARGETDIR := $(LIBDIR)
TARGET := $(subst .a,$(LIBSUFFIX).a,$(LIBDIR)/$(STATIC_LIB))
LINKLINE = ar qv $(TARGET) $(OBJS)
else
LIB += -lcutil$(LIBSUFFIX)
# Device emulation configuration
ifeq ($(emu), 1)
NVCCFLAGS += -deviceemu
CUDACCFLAGS +=
BINSUBDIR := emu$(BINSUBDIR)
# consistency, makes developing easier
CXXFLAGS += -D__DEVICE_EMULATION__
CFLAGS += -D__DEVICE_EMULATION__
endif
TARGETDIR := $(BINDIR)/$(BINSUBDIR)
TARGET := $(TARGETDIR)/$(EXECUTABLE)
LINKLINE = $(LINK) -o $(TARGET) $(OBJS) $(LIB)
endif
check if verbose
ifeq ($(verbose), 1)
VERBOSE :=
else
VERBOSE := @
endif
Check for input flags and set compiler flags appropriately
ifeq ($(fastmath), 1)
NVCCFLAGS += -use_fast_math
endif
ifeq ($(keep), 1)
NVCCFLAGS += -keep
NVCC_KEEP_CLEAN := *.i* *.cubin *.cu.c *.cudafe* *.fatbin.c *.ptx
endif
ifdef maxregisters
NVCCFLAGS += -maxrregcount $(maxregisters)
endif
Add cudacc flags
NVCCFLAGS += $(CUDACCFLAGS)
workaround for mac os x cuda 1.1 compiler issues
ifneq ($(DARWIN),)
NVCCFLAGS += --host-compilation=C
endif
Add common flags
NVCCFLAGS += $(COMMONFLAGS)
CXXFLAGS += $(COMMONFLAGS)
ifeq ($(nvcc_warn_verbose),1)
NVCCFLAGS += $(addprefix --compiler-options ,$(CXXWARN_FLAGS))
endif
Set up object files
OBJDIR := $(ROOTOBJDIR)/$(BINSUBDIR)
OBJS += $(patsubst %.cpp,$(OBJDIR)/%.cpp.o,$(notdir $(CCFILES)))
OBJS += $(patsubst %.c,$(OBJDIR)/%.c.o,$(notdir $(CFILES)))
OBJS += $(patsubst %.cu,$(OBJDIR)/%.cu.o,$(notdir $(CUFILES)))
Set up cubin files
CUBINDIR := $(SRCDIR)data
CUBINS += $(patsubst %.cu,$(CUBINDIR)/%.cubin,$(notdir $(CUBINFILES)))
Rules
$(OBJDIR)/%.c.o : $(SRCDIR)%.c $(C_DEPS)
$(VERBOSE)$(CC) $(CFLAGS) -o $@ -c $<
$(OBJDIR)/%.cpp.o : $(SRCDIR)%.cpp $(C_DEPS)
$(VERBOSE)$(CXX) $(CXXFLAGS) -o $@ -c $<
$(OBJDIR)/%.cpp.o : $(MODULEDIR)%.cpp $(C_DEPS)
$(OBJDIR)/%.cu.o : $(SRCDIR)%.cu $(CU_DEPS)
$(VERBOSE)$(NVCC) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -c $<
$(CUBINDIR)/%.cubin : $(SRCDIR)%.cu cubindirectory
$(VERBOSE)$(NVCC) $(CUBIN_ARCH_FLAG) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -cubin $<
The following definition is a template that gets instantiated for each SM
version (sm_10, sm_13, etc.) stored in SMVERSIONS. It does 2 things:
1. It adds to OBJS a .cu_sm_XX.o for each .cu file it finds in CUFILES_sm_XX.
2. It generates a rule for building .cu_sm_XX.o files from the corresponding
.cu file.
The intended use for this is to allow Makefiles that use common.mk to compile
files to different Compute Capability targets (aka SM arch version). To do
so, in the Makefile, list files for each SM arch separately, like so:
CUFILES_sm_10 := mycudakernel_sm10.cu app.cu
CUFILES_sm_12 := anothercudakernel_sm12.cu
define SMVERSION_template
OBJS += $(patsubst %.cu,$(OBJDIR)/%.cu_$(1).o,$(notdir $(CUFILES_$(1))))
$(OBJDIR)/%.cu_$(1).o : $(SRCDIR)%.cu $(CU_DEPS)
$(VERBOSE)$(NVCC) -o $$@ -c $$< $(NVCCFLAGS) -arch $(1)
endef
This line invokes the above template for each arch version stored in
SM_VERSIONS. The call funtion invokes the template, and the eval
function interprets it as make commands.
$(foreach smver,$(SM_VERSIONS),$(eval $(call SMVERSION_template,$(smver))))
$(TARGET): makedirectories $(OBJS) $(CUBINS) $(LIBDIR)/libcutil.so $(LIBDIR)/libparamgl.so $(LIBDIR)/librendercheckgl.so Makefile
$(VERBOSE)$(LINKLINE)
$(LIBDIR)/libcutil.so:
@make -C $(COMMONDIR)
$(LIBDIR)/libparamgl.so:
@make -C $(COMMONDIR) -f Makefile_paramgl
$(LIBDIR)/librendercheckgl.so:
@make -C $(COMMONDIR) -f Makefile_rendercheckgl
cubindirectory:
$(VERBOSE)mkdir -p $(CUBINDIR)
makedirectories:
$(VERBOSE)mkdir -p $(LIBDIR)
$(VERBOSE)mkdir -p $(OBJDIR)
$(VERBOSE)mkdir -p $(TARGETDIR)
@echo $(COMMON_FLAGS)
tidy :
$(VERBOSE)find . | egrep "#" | xargs rm -f
$(VERBOSE)find . | egrep "\~" | xargs rm -f
clean : tidy
$(VERBOSE)rm -f $(OBJS)
$(VERBOSE)rm -f $(CUBINS)
$(VERBOSE)rm -f $(TARGET)
$(VERBOSE)rm -f $(NVCC_KEEP_CLEAN)
clobber : clean
$(VERBOSE)rm -rf $(ROOTOBJDIR)
[/codebox]
