Deterministic Identity & Continuity Control Plane Validation within NVIDIA Aerial AI-RAN Environment
We recently completed a validation of a deterministic identity and continuity control-plane layer operating within an AI-RAN-aligned simulation environment modeled on NVIDIA Aerial architecture patterns.
This work is part of NOVA X QUANTUM™, with ACELOGIC™ acting as the control-plane layer responsible for enforcing identity, authority, and lifecycle continuity across autonomous systems.
Validation Scope:
  • AI-RAN-aligned simulation environment (distributed RAN execution model)
  • Modeled against NVIDIA Aerial concepts (CUDA-accelerated RAN patterns)
  • Focused on pre-execution enforcement of identity and authority
  • Evaluated under distributed and adversarial lifecycle conditions
Validation Results:
  • Deterministic identity generation at agent instantiation (SHA-256 fingerprint)
  • 100% duplicate prevention across test set (50/50 duplicate attempts blocked)
  • Zero split-brain events observed across all execution scenarios
  • Identity persistence maintained across restart and migration (no drift)
  • SAFE_MODE enforced during network partition (no unauthorized recovery)
  • Multi-verifier authority model reached 100% consensus across all validations
  • Control-plane overhead bounded at ~15 ms per enforcement cycle
Simulation Model:
  • Discrete-event simulation aligned with AI-RAN distributed execution patterns
  • Lifecycle coverage: instantiation, restart, migration, partition, adversarial conditions
  • Enforcement applied prior to execution across all lifecycle states
System Model:
Identity → Authority → Execution → Settlement → Continuity
(Control enforced prior to execution)
Framing Insight:
This work evaluates a missing control layer in autonomous systems infrastructure:
-> deterministic identity
-> enforceable authority
-> lifecycle continuity across distributed environments
Context / Direction
We are now extending this work toward a 6G AI-RAN-aligned control-layer framework, with a focus on integration into Aerial-based deployments and Kubernetes-native execution environments.
We’re currently testing behavior under failover and partition scenarios and are seeing edge cases around dual-active execution in distributed conditions.
Technical Discussion / Feedback Request
Looking for input from engineers working with NVIDIA Aerial or similar distributed RAN environments:
  1. Integration Point
    Where would an identity + authority enforcement layer most naturally sit?
    • Pre-scheduler (admission control)?
    • Pod lifecycle hooks (preStart / restart / migration)?
    • Or as a separate control-plane extension?
  2. Existing Handling
    How are these handled today (if at all)?
    • Prevention of dual-active / duplicate execution
    • Identity continuity during rescheduling or migration
    • Authority/state enforcement during network partition events
  3. Failover Model
    Would a strict fail-closed / SAFE_MODE approach (no execution without re-verification) be viable in production telecom environments, or is partial continuity typically preferred?
Goal:
Understand whether this layer should integrate within Aerial workflows or sit above as an enforcement boundary.
Thank you for sharing.
