Deterministic nvoglv64.dll crash (c0000409 / __fastfail) — RTX 5070 Ti, driver 610.88, always same offset
Summary: Reproducible OpenGL driver crash causing a TDR. 13 consecutive occurrences over 10+ days, every single one faulting at the exact same instruction: nvoglv64.dll+0x010cbbed, exception 0xc0000409 (STATUS_STACK_BUFFER_OVERRUN, driver-initiated __fastfail). The determinism (same offset, zero variance) rules out hardware/electrical causes on my end — this looks like an internal consistency check firing on a specific GL call sequence.
System:
  • GPU: GeForce RTX 5070 Ti (Gigabyte OC), driver 610.88 WHQL (nvoglv64.dll v32.0.16.1088)
  • CPU/Platform: AMD Ryzen 7 9800X3D, MSI B650M PROJECT ZERO (AM5)
  • OS: Windows 11, build 26100
  • Also reproduced (different driver-file version, offset not captured at the time) on driver 591.86
Trigger app: Project Zomboid (ProjectZomboid64.exe) — Java/LWJGL, OpenGL renderer. Not reproducible in D3D titles (Roblox, League, Valorant run for hours under similar/heavier load with zero incidents) — points at something specific to the GL call sequence this engine makes, not general GPU instability.
Crash signature (identical every time):
  1. Event ID 153 (nvlddmkm) burst: repeated “Error occurred on GPUID: n” at a ~2–5s cadence 2. App faults in nvoglv64.dll within 0–3s of1000, exception c0000409, offset 0x010cbbed)
  2. One Resetting TDR / Reset TDR / Restarting TDR sequence 20–35s later (this is cleanup — the app is already dead by this point)
Ruled out on my end (30+ days of testing): thermals (max 56°C), power delivery (max 134W of 300W limit, zero throttle-reason flags across 9,418 telemetry samples), PCIe link health (zero WHEA/AER events, ever), core/memory clock offsets, third-party overlays (Steam Overlay, Medal, Overwolf, Blitz — tested individually with each fully disabled/removed), background RGB/monitoring software (Logitech LampArray, Lian-Li L-Connect — both tested removed), __GL_THREADED_OPTIMIZATIONS=0, TdrDelay regier reinstall. None changed the crash or itsoffset.
Hey, have you managed to permanently fix the nvoglv64.dll / 0xc0000409 crash?
I’m having the same issue on my GTX 1650 and I’ve already tried DDU, different NVIDIA drivers, reinstalling Windows, FPS limits, disabling overlays, etc. Nothing worked.
I was actually planning to buy an RTX 5070 Ti for my new PC built, but seeing you get the exact same crash on a 5070 Ti made me hesitate.
Did you find any solution?
