Like the title says, I can’t see /dev/dxg from Ubuntu running via WSL 2. I manually upgraded to Windows 21354.1 build and I’m stuck on the “Release Preview Channel” rather than a “Dev” channel (due to incoming Windows 11).
Based on the CUDA+WSL docs, I believe I meet the build/kernel version criteria, but I’ve yet to successfully get my GPU visible on WSL.
I’ve seen other reports that CUDA+WSL2 works great on Windows 11, so I guess that leaves me with two questions:
- Is the “Dev” channel required, even though I meet the on-paper build/kernel requirements?
- If not, is there something missing from the NVIDIA docs? (I tried this on a fresh Ubuntu 18.04 LTS install and still failed.)
Btw, the “docs” I’m referencing is this page (CUDA on WSL user guide).
