I have a v4l2src yuv camera that I’m basing off the imx185 driver. Basically I’ve taken the imx185 driver, changed the V4L2 format, and also stubbed out the i2c regmap calls (my camera has no i2c).
The driver probe finishes fine but I see no /dev/video0.
One thing that I don’t get is if in my device tree I use vi@15700000 the kernel crashes. If I do it the old way and just use “vi” it initializes fine. Is that a clue?
clutch12, did you have any success? I have the same problems here.
Some addition: AFAIK, from the Parker TRM 28.6.62. INTR_STATUS 0x00000004 means intr_stat_pd_crc_err_vc0 .
i wish i remember this better. i ended up changing some of the csi stuff in the device tree I think to make this work but its been months so my memory is fuzzy.
I don’t know if it is directly related, but after I changed my ‘badge’ in the tegra-camera-platform part of my device tree file, I didn’t get the ‘PXL_SOF syncpt timeout! err = -11’ error
Edit: Turns out it isn’t. I’m still getting the error
