Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
[*] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
Host Machine Version
[*] native Ubuntu 18.04
other
Hi, Team,
I am try to porting our own ar0820 camera module on Drive Xavier. I try it in libnv_extimgdev.so driver framework and the camera works good. And then i try it in NvSIPL framework. Ser/dser works ok. Camera sensor’s id can read very well, But when i write the camera sensor init register squences, the function DevBlkCDIDeviceWrite always failed after write some registers. The init register squences are same as libnv_extimgdev.so . Whats wrong with it?
We haven’t heard such issue. Please check if any difference between previous successful DevBlkCDIDeviceWrite() calls and the first failed one. Or what’s the returned value or message from the first failed call?
Hi @VickNV
It returned NVMEDIA_STATUS_ERROR. Command dmesg shows tegra-i2c 3160000.i2c: no acknowledge from address 0x19 . I have checked i2c translator config is ok. I think sould be max96712’s config issue.
BTW, how to add my own eeprom i2c address in the query/database/*.json ?
