I have two Jetsons with the B01 board, one of them does not turn on but if I change the Jetson board to another board it works normally. So I am sure that I have a problem with the B01 board, I removed the Jetson and made several measurements and noticed that the TPS25944L output is at 2.5v and the input is 5.0v, while on the board that is working it is 5.0v at the output and 5.0v at the input.
Edit: check if the FLT pin was indicating any fault but it is normal
