An error occurred in the application and your page could not be served. If you are the application owner, check your logs for details. You can do this from the Heroku CLI with the command heroku logs --tail
Could you please fix this issue so I can download the required software?
Thanks in advance!
Hi @yannick.burkhardt1, I’ve been experiencing the same issue all day. Seeing as you’re posting this to the AGX Orin forum, do you per chance also have trouble logging into the SDK? Logging in to the SDK first requires me to log in to Nvidia’s SDK manager website (which works fine), but then the SDK manager itself proceeds to get stuck and revert to the login screen again. I think this might have the same root cause, and it’s very annoying.
Sorry, I did not try that. But I’ve also experienced trouble logging into this forum or replying to your thread after following the notification email. I guess everything that is redirected through developer.nvidia.com or relies on heroku fails.
