Developping Codelets C++ tutorial fail to run
Hi i’m following the Developping Codelets C++ tutorial and my aplication fails when running, displaying the following error:
mojer@mojer:~/isaacsdk/sdk/packages/ping$ bazel run ping
INFO: Analyzed target //packages/ping:ping (0 packages loaded, 0 targets configured).
INFO: Found 1 target...
Target //packages/ping:ping up-to-date:
  bazel-bin/packages/ping/run_ping
  bazel-bin/packages/ping/ping
INFO: Elapsed time: 18.365s, Critical Path: 16.71s
INFO: 1 process: 1 linux-sandbox.
INFO: Build completed successfully, 2 total actions
2021-06-07 12:42:42.845 WARN  external/com_nvidia_isaac_engine/engine/alice/backend/application_json_loader.cpp@183: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system's abilities if possible.
2021-06-07 12:42:42.848 INFO  external/com_nvidia_isaac_engine/engine/alice/backend/redis_backend.cpp@40: Successfully connected to Redis server.
2021-06-07 12:42:42.848 WARN  external/com_nvidia_isaac_engine/engine/alice/backend/backend.cpp@200: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2021-06-07 12:42:42.848 WARN  external/com_nvidia_isaac_engine/engine/gems/scheduler/scheduler.cpp@341: No default execution groups specified. Attempting to create scheduler configuration for 1 remaining cores. This may be non optimal for the system and application.
|                            Isaac application terminated unexpectedly                             |
#01 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x6cc1a) [0x55bfa2597c1a]
#02 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xe3e80) [0x55bfa260ee80]
#03 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xe41f0) [0x55bfa260f1f0]
#04 /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980) [0x7f963a4f5980]
#05 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xcb445) [0x55bfa25f6445]
#06 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xcea52) [0x55bfa25f9a52]
#07 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xcef7d) [0x55bfa25f9f7d]
#08 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x61502) [0x55bfa258c502]
#09 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x3393f) [0x55bfa255e93f]
#10 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x33dbf) [0x55bfa255edbf]
#11 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x12873) [0x55bfa253d873]
#12 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f9639b72bf7]
#13 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x17eca) [0x55bfa2542eca]
Minidump written to: /tmp/9fa88e63-5bc3-42d8-53c36eb8-635f218c.dmp
I’m using a virtual machine of Ubuntu 18.04 and my computer has a NVIDIA GeForce GTX 1060
Anyone knows how to solve it?
I’m having the same problems running the tutorial, running the nvidia docker image on a GeForce RTX 3060. Unable to get it working at all.
Solved it for me; I had specified start(), tick() and stop() as override in the hpp file but had not implemented all of them in the cpp file. Fixing it solved the crash.
