I was able to install TF in a virtual env in my orin device. I have preiusly confirm that TF-GPU is correctly installed and i was able to run some codes. However no i cant train any model and when running “tf.test.is_gpu_available()” in command window shows the below log
ARNING:tensorflow:From :1: is_gpu_available (from tensorflow.python.framework.test_util) is deprecated and will be removed in a future version.
Instructions for updating:
Use tf.config.list_physical_devices('GPU')
instead.
2023-11-21 23:34:50.619499: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
Your kernel may have been built without NUMA support.
2023-11-21 23:34:50.655103: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-11-21 23:34:50.655312: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-11-21 23:34:51.280649: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-11-21 23:34:51.280954: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-11-21 23:34:51.281023: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1708] Could not identify NUMA node of platform GPU id 0, defaulting to 0. Your kernel may not have been built with NUMA support.
2023-11-21 23:34:51.281137: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-11-21 23:34:51.281260: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1621] Created device /device:GPU:0 with 1200 MB memory: → device: 0, name: Orin, pci bus id: 0000:00:00.0, compute capability: 8.7
True
which exactly the same error when trying to train some models in juypyter notebook
