Device control with the xavier nx using ppm guidance and help
hello. I wish to connect a servo to the jetson xavier nx via a ppm cable and control it. How best can i go about this? anyone tried this? Thanks.
Maybe this can help?
thank you very much. this indeed is helpful. But cant i just bypass the breakout board? I only wish to control one servo for now. So connecting Checking the xavier nx documentation, I see some pins like [2 and 4] providing up to 5vdc of power and ground. So what configuration changes and precautions do you suggest i take and look out for in order to directly connect the servo ppm to one of the i2c, power, ground pins for my app? Again thanks. I got a starting point at least.
hello user86373,
here’s expansion header you may check for setting up pin connections,
thanks
I will try connecting directly to pwm pins then. thanks.
