Device crashed through the debug serial port only print crash information
Software Version
DRIVE OS 6.0.5
Target Operating System
Linux
Hardware Platform
Host Machine Version
Trigger method: Continuously running a program on the device.
Symptoms: The device fan is spinning, the indicator light is on, and the 1GB Ethernet port’s indicator light is on. ping the device through the jumper machine does not work, and ssh into the device gets stuck. Connecting to the debug serial port outputs crash information.
After restarting, the device returns to normal.
putty.log (152.1 KB)
Can anyone provide an suggestion
I would recommend upgrading to DRIVE OS 6.0.6, if you haven’t already done so. Upgrading to the latest version of the operating system often includes bug fixes, stability improvements, and enhancements that can help resolve such crashes. By upgrading, you may potentially overcome this issue and prevent similar crashes in the future.
@VickNV Hi. How can we solve or workaround this problem, due to other reasons, DRIVE OS can not be upgraded.
After checking with our team internally, you have another support channel instead of this forum. If you’re unsure, please contact your NVIDIA representative for further clarification.
