I became excited when I read about DDT supporting device debugging starting with PGI 14.1 [1]. When trying to run a CUDA Fortran program, DDT correctly recognizes a multithreaded environment, however on trying to step it fails with “Allinea DDT could not step: Cannot find bounds of current function”. Do I have to compile differently? I couldn’t find any documentation on this feature.
I need a bit more context here, can please answer following questions :
Are you compiling CUDA Fortran code or OpenACC code ? Options that you provide are applying to both.
Can you share the code ? or send me the generated .gpu file ?
By the way steping from Host code to Kernel code may not work, did you try to set a breakpoint in CUDA Fortran kernel and run to this kernel ?
Thanks a lot for your time. I’m a bit confused by the question “Are you compiling CUDA Fortran code or OpenACC code” Does the Mcuda-option really apply to OpenACC as well? In that case that would be something new for me. Anyway, it’s CUDA Fortran (like mentioned in my first post).
I think I may still misunderstand how device debugging is supposed to work - as I wrote I can’t find any documentation on this, would you have any pointers? Anyway, do I have to load the GPU file into the debugger? If so, how do you initialize the kernels correctly, without loading the host code as well? I’d gladly send you the source code and/or binaries, I’d just like to know a bit more about the process before causing you too much work.
I know it worked at some point, but right now I can’t get DDT to play well together with PGI OpenACC. When trying to step into device code, it does show threadidx / blockidx / blockdim under “locals”, but the editor window stays on the kernel call in host code, i.e. I’m blind on what code has exactly executed on the device. Switching to device threads it usually shows that it’s within cuda_wait or cuda_launch (C Files probably coming from PGI’s wrapper around CUDA). Is there something I’m doing wrong when compiling?
I sent a note to Seb to see if he can help but he’s on vacation this week.
I don’t know enough about DDT to answer this. Can you send the question to Allinea? Seb worked with them to ensure PGI was producing correct dwarf code, so knows more than I, but Allinea would have better insight on the operation of DDT.
Can you advise customer to try to set a breakpoint inside ACC region and launch run in DDT. I’m not sure stepping from host code to device code will work.
