Device Derived Types
Is there a way to define a derived type as device variables so the entire type can be passed to the GPU kernel in the GPU subroutine call in the host program?
Provided that the UDT is fixed size (i.e. no allocatable) then, yes, you can uses these with both CUDA Fortran and OpenACC.
  • Mat
Here is the code I am trying to test this on:
MODULE GPUModule
use cudafor
implicit none
type globalvar
real8:: a
real
8:: x(10)
real8:: y(10)
real
8:: z(10)
end type globalvar
CONTAINS
attributes(global) subroutine sumv(gvar)
type(globalvar)::gvar
integer i
i = (blockidx%x-1) * blockdim%x + threadidx%x
gvar%z(i)=gvar%a*gvar%x(i)+gvar%y(i)
end subroutine sumv
end MODULE GPUMODULE
PROGRAM testgpu
use GPUModule
use cudafor
implicit none
type(globalvar) gvar
integer,parameter :: n=10
integer i,istat
real8 zn
gvar%a=5
do i=1,n
gvar%x(i)=i
gvar%y(i)=i
enddo
call sumv<<<1,n>>>(gvar)
zn=gvar%z(2)
write(
,*) zn
end PROGRAM
As written, the compiler gives me an error of device attribute mismatch when calling the sumv routine. What do I need to do to define my type such that it is passed to the kernel as a device variable?
gvar needs to be declared with the device attribute otherwise it’s a host variable.
PROGRAM testgpu
use GPUModule
use cudafor
implicit none
type(globalvar), device :: gvar
Hope this helps,
Mat
Is there a way to define a type or a type within another type as constant or shared or can they only be defined as device variables?
