I am hoping for some help with a problem I am having with a device function. This function is called from my kernel. I want the function to interpolate a value for me. When I return the calculated value the function doesn’t work and gives “unknown error”. When I hard code a return value it works well. Please offer any suggestions you may have as I have exhausted the resources allocated by my brain at the moment. Thanks!
Here is the device function called from a working kernel:
__device__ float g_GetPartDepthAt(float3* pathPosition, float4* d_partTopSurface)
float voxelSize = 0.08025;
int xDim = 104;
int xCeil = ceilf( (pathPosition->x) / voxelSize);
int xFloor = floorf( (pathPosition->x) / voxelSize);
float xDelta = (pathPosition->x) / voxelSize - xFloor;
int yCeil = ceilf( (pathPosition->y) / voxelSize);
int yFloor = floorf( (pathPosition->y) / voxelSize);
float yDelta = (pathPosition->y) / voxelSize - yFloor;
int bottLeft = yFloor * xDim + xFloor;
int topRight = yCeil * xDim + xCeil;
int bottRight = yFloor * xDim + xCeil;
int topLeft = yCeil * xDim + xFloor;
float distX0_Y0 = d_blankTopSurface[bottLeft].w;
float distX1_Y1 = d_blankTopSurface[topRight].w;
float distX1_Y0 = d_blankTopSurface[bottRight].w;
float distX0_Y1 = d_blankTopSurface[topLeft].w;
float value1 = distX0_Y0 + xDelta * (distX1_Y0 - distX0_Y0);
float value2 = distX0_Y1 + xDelta * (distX1_Y1 - distX0_Y1);
float ans = (value1 + yDelta * (value2 - value1));
return 1.0;
//return ans;
In the above function, I would like to return ans. Unfortunately, this doesn’t work. It works when I return a hard coded value like 1.0 as shown.
Any help you can offer is greatly appreciated.
Grateful,
Joshua
