Device memory r/w operations
Is it documented if operations that operate on device memory (read, write), whether that memory is accessed via the global or texture spaces, are asynchronous?
Consider the following code:
texture<float, 1, cudaReadModeElementType> data;
__global__ void opsGPU(float* d_out, int outSize)
   const int blockStart = IMUL(blockIdx.x, THREADS_PER_BLOCK);
   const int writePos = blockStart + threadIdx.x;
  float in;
  if(writePos < outSize)
      in = tex1Dfetch(data, writePos);
     ->(some operations that do not require the fetch, ops1)
    ->(some operations that require the fetch, ops2)
      d_out[writePos] = some_result;
Will execution be returned to the thread for ops1 at which point the thread waits on the fetch and can be swapped out for a different one? Or do both ops1 and ops2 be waiting for the fetch? Could there be a compilation optimization in place where ops1 is swapped to be above the fetch?
In the same sense, is it reasonable to do:
d_out[threadPos] = d_in1[threadPos]-d_in2[threadPos]
or
float in1 = d_in1[threadPos];
float in2 = d_in2[threadPos];
d_out[threadPos] = in1-in2;
or does it all reduce to that during compilation? External Image
thanks for any replies,
Konstantinos
