I am having custom board, with i2c device connected over I2C_GP0_DAT(GEN1_I2C_SDA) and CLK on the same i2c.
So it should be on /dev/i2c-0 i.e. i2c bus 0.
Is my assumption correct?
I have also added new sub node under dtsi file for i2c node i2c@7000c000 as i want to load appropriate driver for i2c chip.
Is adding sub node under i2c@7000c000 correct for device on i2c bus 0?
But i could not see device when i run i2cdetect -y -r 0
What could be the reason for device not being able to detect on i2c bus 0?
I am using rel 24.2.1 of Tegra kernel.
Thanks,
Prathamesh
