Howdy, I have a 9800GX2 and a c1060. See device Query below:
[codebox]Device 0: “GeForce 9800 GX2”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 536608768 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.51 GHz
Concurrent copy and execution: Yes
Device 1: “GeForce 9800 GX2”
Total amount of global memory: 536543232 bytes
Warp size: 32
Device 2: “Tesla C1060”
Minor revision number: 3
Total amount of global memory: 4294705152 bytes
Number of multiprocessors: 30
Number of cores: 240
Total number of registers available per block: 16384
Warp size: 32
Clock rate: 1.30 GHz
Test PASSED[/codebox]
I am using atomicExch() for shared memory which requires > rev 1.2 hardware. So, I compile for 1.3 for the c1060. If I run the code using device 2 I get a whole bunch of random garbage as output, but if I use device 0 the results are reasonable. Is the system seeing that the c1060 is the only 1.3 card and assigning it device 0 or am I missing something? None of this makes any sense. Thanks
