The SDK kit that he is referring to solve my problem requires atleast 8 gb of ram while the original system being discussed is 2 gb. Unless I am understanding this wrong, how do I solve this issue?
Could you provide the link in the screenshot you refer to for further check?
What is your jetpack version in Jetson Nano?
and how did you flash your board?
I found out the solution, apparently there just some bug where you need to close the terminal and run it again. Then it asks for the login and password and youre in.
