Originally, I had been working on a qt UI project (made use of libargus) with L4T R28.2.1. I ended up reflashing my TX2 with a newer version of L4T R32.1. This was provided by Leopard Imaging with support for their IMX185 camera kit. However, I am getting a runtime error. It seems to have something to do with the device tree.
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
I haven’t been able to find a conclusive answer on the forums for what I need to do or change to solve this issue.
The log:
NvPclHwGetModuleList: No module data found
---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
NvCameraIspConfigFileLoad: type = 0x75 Config file "sensor.cfg" Line 526: Error: Invalid isp config attribute: "detailenhancement.NumOfEntries=9"
CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
CAM: serial no file already exists, skips storing againCannot get core camera provider interface
Created Camera Provider
(Argus) Error InvalidState: Object was already destroyed (in src/common/ObjectImpl.cpp, function destroyClientReference(), line 47)
Press <RETURN> to close this window...
