I’m currently trying to port camera drivers which were originally for Jetson 4.6 on AGX Xavier to Jetson 5.0 on Jetson Orin. I’m getting this error: FATAL ERROR: Unable to parse input tree
Relevant definitions:
#define CAM1_RST_L TEGRA234_MAIN_GPIO(T, 6)
#define CAM1_PWDN TEGRA234_MAIN_GPIO(T, 5)
Portion where error is received:
i2c@2 {
reg = <2>;
i2c-mux,deselect-on-exit;
#address-cells = <1>;
#size-cells = <0>;
dser_e: max9296@48 {
compatible = "nvidia,max9296";
reg = <0x48>;
csi-mode = "2x4";
max-src = <2>;
reset-gpios = <&tegra_main_gpio CAM1_RST_L GPIO_ACTIVE_HIGH>;
ser_e: max9295@62 {
compatible = "nvidia,max9295";
reg = <0x62>;
ar0820_e@10 {
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
def-addr = <0x10>;
clocks = <&bpmp_clks TEGRA234_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA234_CLK_EXTPERIPH1>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
nvidia,gmsl-ser-device = <&ser_e>;
nvidia,gmsl-dser-device = <&dser_e>;
The error points to the line reset-gpios = <&tegra_main_gpio CAM1_RST_L GPIO_ACTIVE_HIGH>;reset-gpios = <&tegra_main_gpio CAM1_RST_L GPIO_ACTIVE_HIGH>;
(I think) I’ve narrowed the problem down to T5 and T6 being the wrong pins for CAM1, but I can’t find any documentation about what the correct pins would be. How do I solve this error?
