Hi
I want to do some modifications in the deice tree settings in my Jetson Nano and I have read the adaption guide document provided by Nvidia and some other documents and this part is still vague for me. I was wondering if you could give me more simple and understandable explanations and some guidance on the USB part of the device tree settings.
xusb_padctl@7009f000 {
compatible = "nvidia,tegra210-xusb-padctl";
reg = <0x0 0x7009f000 0x0 0x1000>;
reg-names = "padctl";
resets = <0x21 0x8e>;
reset-names = "padctl";
status = "okay";
vddio-hsic-supply = <0x3d>;
avdd_pll_uerefe-supply = <0x3e>;
hvdd_pex_pll_e-supply = <0x36>;
dvdd_pex_pll-supply = <0x3f>;
hvddio_pex-supply = <0x36>;
dvddio_pex-supply = <0x3f>;
hvdd_sata-supply = <0x36>;
dvdd_sata_pll-supply = <0x40>;
hvddio_sata-supply = <0x36>;
dvddio_sata-supply = <0x40>;
linux,phandle = <0x44>;
phandle = <0x44>;
pads {
usb2 {
clocks = <0x21 0xd2>;
clock-names = "trk";
status = "okay";
lanes {
usb2-0 {
status = "okay";
#phy-cells = <0x0>;
nvidia,function = "xusb";
linux,phandle = <0x45>;
phandle = <0x45>;
usb2-1 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0x49>;
phandle = <0x49>;
usb2-2 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0x4a>;
phandle = <0x4a>;
usb2-3 {
status = "disabled";
#phy-cells = <0x0>;
pcie {
clocks = <0x21 0x107>;
clock-names = "pll";
resets = <0x21 0xcd>;
reset-names = "phy";
status = "okay";
lanes {
pcie-0 {
status = "okay";
#phy-cells = <0x0>;
nvidia,function = "pcie-x1";
linux,phandle = <0x85>;
phandle = <0x85>;
pcie-1 {
status = "okay";
#phy-cells = <0x0>;
nvidia,function = "pcie-x4";
linux,phandle = <0x81>;
phandle = <0x81>;
pcie-2 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0x82>;
phandle = <0x82>;
pcie-3 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0x83>;
phandle = <0x83>;
pcie-4 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0x84>;
phandle = <0x84>;
pcie-5 {
status = "okay";
#phy-cells = <0x0>;
ports {
usb2-0 {
status = "okay";
vbus-supply = <0x41>;
mode = "otg";
nvidia,usb3-port-fake = <0x3>;
usb2-1 {
status = "okay";
vbus-supply = <0x42>;
mode = "host";
linux,phandle = <0xb4>;
phandle = <0xb4>;
usb2-2 {
status = "okay";
vbus-supply = <0x43>;
mode = "host";
usb2-3 {
usb3-0 {
status = "okay";
nvidia,usb2-companion = <0x1>;
usb3-1 {
hsic-0 {
In case I want to modify this to use one usb what should I do? So I modify it in a way that one usb is connected directly to Jetson Nano not to the hub ( Because I have my own custom board).
