I am trying to set up CUDA on a macbook pro with an 8600M GT. I’ve tried multiple versions of CUDA, and finally am able to get deviceQuery to work with 2.2 and 2.3a. Currently I have 2.3a installed. However, when I try to run bandwidthTest, or any of the other example programs, it fails:
[codebox]/Developer/GPU Computing/C/bin/darwin/release$ ./deviceQuery
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “GeForce 8600M GT”
CUDA Driver Version: 2.30
CUDA Runtime Version: 2.30
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 134021120 bytes
Number of multiprocessors: 4
Number of cores: 32
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.94 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: No
Compute mode: Default (multiple host threads can use this device simultaneously)
Test PASSED
Press ENTER to exit…
/Developer/GPU Computing/C/bin/darwin/release$ ./bandwidthTest
Running on…
device 0:GeForce 8600M GT
Quick Mode
Host to Device Bandwidth for Pageable memory
cudaSafeCall() Runtime API error in file <bandwidthTest.cu>, line 647 : no CUDA-capable device is available.
/Developer/GPU Computing/C/bin/darwin/release$ ./nbody
Run “nbody -benchmark [-n=]” to measure perfomance.
cudaSafeCall() Runtime API error in file <bodysystemcuda.cu>, line 79 : out of memory.
[/codebox]
Any advice?
