Hello Eric, first of all thanks for taking the time to help!
Below you’ll find the requested outputs:
date
Tue Sep 15 09:16:56 AM CEST 2026
uptime
09:18:48 up 19:07, 3 users, load average: 0.01, 0.01, 0.00
cat /etc/nv_tegra_release
# R39 (release), REVISION: 2.1, GCID: 46758480, BOARD: generic, EABI: aarch64, DATE: Fri Aug 7 05:54:22 AM UTC 2026
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
sudo nvpmodel -q
NV Power Mode: MAXN_SUPER2
ps -eo pid,ppid,user,comm,%cpu,%mem,rss,etime,args --sort=-%cpu | head -30
312 296 root (udev-worker) 0.3 0.0 3832 19:09:19 (udev-worker)
32881 2 root kworker/u12:1-d 0.3 0.0 0 03:38:50 [kworker/u12:1-devfreq_wq]
296 1 root systemd-udevd 0.1 0.0 7304 19:09:19 /usr/lib/systemd/systemd-udevd
1491 2 root nvgpu_channel_p 0.1 0.0 0 19:09:16 [nvgpu_channel_poll_ga10b]
13123 12085 orinnano gnome-shell 0.1 2.7 210076 16:20:26 /usr/bin/gnome-shell
2165 1 root containerd 0.0 0.2 20284 19:09:14 /usr/bin/containerd
13607 13303 orinnano python3 0.0 0.1 12972 16:20:23 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
1806 1 root wpa_supplicant 0.0 0.0 5720 19:09:15 /usr/sbin/wpa_supplicant -u -s -O DIR=/run/wpa_supplicant GROUP=netdev
630 1 message+ dbus-daemon 0.0 0.0 5112 19:09:17 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
78 2 root kswapd0 0.0 0.0 0 19:09:26 [kswapd0]
40119 2170 root sshd 0.0 0.1 8792 05:29 sshd: orinnano [priv]
13303 13092 orinnano python3 0.0 0.3 29396 16:20:24 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
1786 1 root nvfancontrol 0.0 0.0 1352 19:09:15 /usr/sbin/nvfancontrol &
13317 13092 orinnano gnome-software 0.0 0.4 37800 16:20:24 /usr/bin/gnome-software --gapplication-service
20761 2 root kworker/2:0-eve 0.0 0.0 0 13:08:44 [kworker/2:0-events]
2207 1 root dockerd 0.0 0.3 27320 19:09:13 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
1778 1 root NetworkManager 0.0 0.1 11464 19:09:15 /usr/sbin/NetworkManager --no-daemon
2146 2 root RTW_CMD_THREAD 0.0 0.0 0 19:09:14 [RTW_CMD_THREAD]
12340 1 orinnano code-645f29cc31 0.0 0.1 10572 16:35:23 /home/orinnano/.vscode-server/code-645f29cc3176500b4b5762ba887cf2a7f0ffdf2c --cli-data-dir /home/orinnano/.vscode-server/cli agent host
599 2 root nvmap-bz 0.0 0.0 0 19:09:17 [nvmap-bz]
1 0 root systemd 0.0 0.1 10668 19:09:26 /sbin/init 2
217 1 root systemd-journal 0.0 0.2 18804 19:09:20 /usr/lib/systemd/systemd-journald
40183 40182 orinnano bash 0.0 0.0 4760 05:25 -bash
54 2 root kcompactd0 0.0 0.0 0 19:09:26 [kcompactd0]
6066 2 root kworker/1:1-eve 0.0 0.0 0 18:47:02 [kworker/1:1-events]
36576 2 root kworker/u13:0-e 0.0 0.0 0 02:24:39 [kworker/u13:0-events_freezable_power_]
39990 2 root kworker/u13:6-e 0.0 0.0 0 41:57 [kworker/u13:6-events_freezable_power_]
sudo nvidia-smi
Tue Sep 15 09:21:12 2026
| NVIDIA-SMI 595.78 Driver Version: 595.78 CUDA Version: 13.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Orin (nvgpu) N/A | N/A N/A | N/A |
| N/A N/A N/A N/A / N/A | Not Supported | N/A N/A |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
systemctl --type=service --state=running --no-pager
UNIT LOAD ACTIVE SUB DESCRIPTION
accounts-daemon.service loaded active running Accounts Service
auditd.service loaded active running Security Auditing Service
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
bluetooth.service loaded active running Bluetooth service
colord.service loaded active running Manage, Install and Generate Color Profiles
containerd.service loaded active running containerd container runtime
cron.service loaded active running Regular background program processing daemon
dbus.service loaded active running D-Bus System Message Bus
docker.service loaded active running Docker Application Container Engine
fwupd.service loaded active running Firmware update daemon
gdm.service loaded active running GNOME Display Manager
gnome-remote-desktop.service loaded active running GNOME Remote Desktop
haveged.service loaded active running Entropy Daemon based on the HAVEGE algorithm
iperf3.service loaded active running iperf3 server
kerneloops.service loaded active running Tool to automatically collect and submit kernel crash signatures
lpd.service loaded active running LSB: BSD lpr/lpd line printer spooling system
ModemManager.service loaded active running Modem Manager
NetworkManager.service loaded active running Network Manager
nv-tee-supplicant.service loaded active running OP-TEE Client Supplicant
nvargus-daemon.service loaded active running Argus daemon
nvfancontrol.service loaded active running nvfancontrol service
nvidia-pva-allowd.service loaded active running service for managing PVA allowlists
nvmemwarning.service loaded active running Display Low memory warning
polkit.service loaded active running Authorization Manager
power-profiles-daemon.service loaded active running Power Profiles daemon
rsyslog.service loaded active running System Logging Service
rtkit-daemon.service loaded active running RealtimeKit Scheduling Policy Service
seatd.service loaded active running Seat management daemon
serial-getty@ttyGS0.service loaded active running Serial Getty on ttyGS0
serial-getty@ttyTCU0.service loaded active running Serial Getty on ttyTCU0
ssh.service loaded active running OpenBSD Secure Shell server
switcheroo-control.service loaded active running Switcheroo Control Proxy service
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running User Login Management
systemd-networkd.service loaded active running Network Configuration
systemd-resolved.service loaded active running Network Name Resolution
systemd-timesyncd.service loaded active running Network Time Synchronization
systemd-udevd.service loaded active running Rule-based Manager for Device Events and Files
udisks2.service loaded active running Disk Manager
upower.service loaded active running Daemon for power management
user@1000.service loaded active running User Manager for UID 1000
wpa_supplicant.service loaded active running WPA supplicant
Legend: LOAD → Reflects whether the unit definition was properly loaded.
ACTIVE → The high-level unit activation state, i.e. generalization of SUB.
SUB → The low-level unit activation state, values depend on unit type.
sudo timeout 30 tegrastats --interval 1000
09-15-2026 09:22:03 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.156C/47.156C soc2@46.406C/46.406C soc0@47.531C/47.531C gpu@48.218C/48.218C tj@48.25C/48.25C soc1@48.25C/48.25C VDD_IN 4735mW/4735mW/4735mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1444mW/1444mW
09-15-2026 09:22:04 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.468C/47.468C soc2@46.406C/46.406C soc0@47.531C/47.531C gpu@48.468C/48.468C tj@48.468C/48.468C soc1@48.406C/48.406C VDD_IN 4735mW/4735mW/4735mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1444mW/1444mW
09-15-2026 09:22:05 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.312C/47.468C soc2@46.375C/46.406C soc0@47.562C/47.562C gpu@48.437C/48.468C tj@48.437C/48.468C soc1@48.281C/48.406C VDD_IN 4735mW/4735mW/4735mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1444mW/1444mW
09-15-2026 09:22:06 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.531C/47.531C soc2@46.468C/46.468C soc0@47.562C/47.562C gpu@48.343C/48.468C tj@48.281C/48.468C soc1@48.281C/48.406C VDD_IN 4735mW/4735mW/4735mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1444mW/1444mW
09-15-2026 09:22:07 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.25C/47.531C soc2@46.531C/46.531C soc0@47.562C/47.562C gpu@48.156C/48.468C tj@48.281C/48.468C soc1@48.281C/48.406C VDD_IN 4694mW/4727mW/4735mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1444mW/1444mW
09-15-2026 09:22:08 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.187C/47.531C soc2@46.562C/46.562C soc0@47.5C/47.562C gpu@48.281C/48.468C tj@48.281C/48.468C soc1@48.25C/48.406C VDD_IN 4775mW/4735mW/4775mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1444mW/1444mW
09-15-2026 09:22:09 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.093C/47.531C soc2@46.468C/46.562C soc0@47.5C/47.562C gpu@48.656C/48.656C tj@48.656C/48.656C soc1@48.25C/48.406C VDD_IN 4775mW/4741mW/4775mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1444mW/1444mW
09-15-2026 09:22:10 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [5%@729,1%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.062C/47.531C soc2@46.437C/46.562C soc0@47.531C/47.562C gpu@48.312C/48.656C tj@48.312C/48.656C soc1@48.25C/48.406C VDD_IN 4735mW/4740mW/4775mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1444mW/1444mW
09-15-2026 09:22:11 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@46.968C/47.531C soc2@46.375C/46.562C soc0@47.468C/47.562C gpu@48.25C/48.656C tj@48.25C/48.656C soc1@48.031C/48.406C VDD_IN 4694mW/4735mW/4775mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1404mW/1440mW/1444mW
09-15-2026 09:22:12 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@46.875C/47.531C soc2@46.343C/46.562C soc0@47.531C/47.562C gpu@48.562C/48.656C tj@48.562C/48.656C soc1@48.156C/48.406C VDD_IN 4694mW/4731mW/4775mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1440mW/1444mW
09-15-2026 09:22:13 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.031C/47.531C soc2@46.406C/46.562C soc0@47.468C/47.562C gpu@48.218C/48.656C tj@48.218C/48.656C soc1@48.125C/48.406C VDD_IN 4694mW/4727mW/4775mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1404mW/1437mW/1444mW
09-15-2026 09:22:14 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@46.875C/47.531C soc2@46.375C/46.562C soc0@47.468C/47.562C gpu@48.437C/48.656C tj@48.437C/48.656C soc1@48.125C/48.406C VDD_IN 4694mW/4725mW/4775mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1404mW/1434mW/1444mW
09-15-2026 09:22:15 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.375C/47.531C soc2@46.406C/46.562C soc0@47.375C/47.562C gpu@48.218C/48.656C tj@48.25C/48.656C soc1@48.25C/48.406C VDD_IN 4775mW/4728mW/4775mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1435mW/1444mW
09-15-2026 09:22:16 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.187C/47.531C soc2@46.406C/46.562C soc0@47.656C/47.656C gpu@48.156C/48.656C tj@48.5C/48.656C soc1@48.5C/48.5C VDD_IN 4815mW/4735mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1435mW/1444mW
09-15-2026 09:22:17 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,1%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.343C/47.531C soc2@46.406C/46.562C soc0@47.375C/47.656C gpu@48.375C/48.656C tj@48.375C/48.656C soc1@48.312C/48.5C VDD_IN 4694mW/4732mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1436mW/1444mW
09-15-2026 09:22:18 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.281C/47.531C soc2@46.5C/46.562C soc0@47.625C/47.656C gpu@48.781C/48.781C tj@48.781C/48.781C soc1@48.281C/48.5C VDD_IN 4694mW/4730mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1404mW/1434mW/1444mW
09-15-2026 09:22:19 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.281C/47.531C soc2@46.593C/46.593C soc0@47.562C/47.656C gpu@48.343C/48.781C tj@48.343C/48.781C soc1@48.218C/48.5C VDD_IN 4694mW/4727mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1435mW/1444mW
09-15-2026 09:22:20 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,1%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.062C/47.531C soc2@46.375C/46.593C soc0@47.562C/47.656C gpu@48.25C/48.781C tj@48.718C/48.781C soc1@48.218C/48.5C VDD_IN 4694mW/4726mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/440mW VDD_SOC 1444mW/1435mW/1444mW
09-15-2026 09:22:21 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,1%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47C/47.531C soc2@46.406C/46.593C soc0@47.437C/47.656C gpu@48.625C/48.781C tj@48.625C/48.781C soc1@48.062C/48.5C VDD_IN 4694mW/4724mW/4815mW VDD_CPU_GPU_CV 441mW/440mW/441mW VDD_SOC 1444mW/1436mW/1444mW
09-15-2026 09:22:22 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@46.875C/47.531C soc2@46.375C/46.593C soc0@47.531C/47.656C gpu@48.25C/48.781C tj@48.25C/48.781C soc1@48.187C/48.5C VDD_IN 4694mW/4722mW/4815mW VDD_CPU_GPU_CV 441mW/440mW/441mW VDD_SOC 1444mW/1436mW/1444mW
09-15-2026 09:22:23 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.406C/47.531C soc2@46.406C/46.593C soc0@47.468C/47.656C gpu@48.468C/48.781C tj@48.468C/48.781C soc1@48.125C/48.5C VDD_IN 4815mW/4727mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/441mW VDD_SOC 1444mW/1436mW/1444mW
09-15-2026 09:22:24 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.437C/47.531C soc2@46.406C/46.593C soc0@47.468C/47.656C gpu@48.5C/48.781C tj@48.5C/48.781C soc1@48.187C/48.5C VDD_IN 4694mW/4725mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/441mW VDD_SOC 1404mW/1435mW/1444mW
09-15-2026 09:22:25 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.5C/47.531C soc2@46.375C/46.593C soc0@47.437C/47.656C gpu@48.187C/48.781C tj@48.312C/48.781C soc1@48.312C/48.5C VDD_IN 4694mW/4724mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/441mW VDD_SOC 1444mW/1435mW/1444mW
09-15-2026 09:22:26 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.437C/47.531C soc2@46.343C/46.593C soc0@47.625C/47.656C gpu@48.218C/48.781C tj@48.312C/48.781C soc1@48.312C/48.5C VDD_IN 4694mW/4723mW/4815mW VDD_CPU_GPU_CV 440mW/440mW/441mW VDD_SOC 1404mW/1434mW/1444mW
09-15-2026 09:22:27 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,1%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.437C/47.531C soc2@46.312C/46.593C soc0@47.531C/47.656C gpu@48.343C/48.781C tj@48.343C/48.781C soc1@48.312C/48.5C VDD_IN 4694mW/4722mW/4815mW VDD_CPU_GPU_CV 441mW/440mW/441mW VDD_SOC 1404mW/1433mW/1444mW
09-15-2026 09:22:28 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.281C/47.531C soc2@46.5C/46.593C soc0@47.656C/47.656C gpu@48.187C/48.781C tj@48.25C/48.781C soc1@48.25C/48.5C VDD_IN 4775mW/4724mW/4815mW VDD_CPU_GPU_CV 441mW/440mW/441mW VDD_SOC 1444mW/1433mW/1444mW
09-15-2026 09:22:29 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@47.093C/47.531C soc2@46.375C/46.593C soc0@47.5C/47.656C gpu@48.343C/48.781C tj@48.343C/48.781C soc1@48.062C/48.5C VDD_IN 4694mW/4723mW/4815mW VDD_CPU_GPU_CV 441mW/440mW/441mW VDD_SOC 1444mW/1434mW/1444mW
09-15-2026 09:22:30 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@46.968C/47.531C soc2@46.437C/46.593C soc0@47.5C/47.656C gpu@48.312C/48.781C tj@48.312C/48.781C soc1@48.281C/48.5C VDD_IN 4815mW/4726mW/4815mW VDD_CPU_GPU_CV 441mW/440mW/441mW VDD_SOC 1444mW/1434mW/1444mW
09-15-2026 09:22:31 RAM 1687/7546MB (lfb 85x4MB) SWAP 354/2048MB (cached 121MB) CPU [0%@729,0%@729,0%@729,0%@729,0%@729,0%@729] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVDEC0 off NVJPG0 off NVJPG1 off VIC off OFA off APE 200 cpu@46.875C/47.531C soc2@46.406C/46.593C soc0@47.375C/47.656C gpu@48.718C/48.781C tj@48.718C/48.781C soc1@48.218C/48.5C VDD_IN 4694mW/4725mW/4815mW VDD_CPU_GPU_CV 441mW/440mW/441mW VDD_SOC 1404mW/1433mW/1444mW
