In webinar slides for DeepStream SDK 2.0 is mentioned Dewarp plugin to dewarp fisheye video stream. I cannot find anything about it anywhere else. Could you help?
Thank you
Thank you
which webinar slides mention dewarp plugin?
We don’t have dewarp plugin.
You can refer to here: https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-plugins-bad/html/gst-plugins-bad-plugins-dewarp.html
Hi Jan,
dewarp plugin is using raw RGB/YUV as input/output, so if you want to use this plugin, pls make sure NVPlugin be correctly negotiated with dewarp.
Note, Most NvPlugins use NvBufSurface as input.
wayne zhu
Thank you for your feedback.
Webinar I refer to is: http://developer.download.nvidia.com/embedded/webinars/DeepStream_SDK_2_0_Webinar_20180718.pdf
